alc269 does not work
can you please look into mine, I tried everything out there for ALC269 and I only got as far as the sound working with no internal mic. and the sounds is very low. please help.
I am running ML on Acer Iconia w700. I attached my DSDT/Codec dump
Iconia W700 2.zip
should I modify my DSDT? with this? or just apply AppleHDA file?
Store (Package (0x0c)
"built-in",
Buffer (One)
0x00
"layout-id",
Buffer (0x04)
0x0C, 0x00, 0x00, 0x00
"PinConfigurations",
Buffer (0x00)
0x00
}, Local0)
Return (Local0)
You need to patch your DSDT, but for this AppleHDA.kext you'll need layout-id 01 instead of 0C.
Mavericks 10.9.2 Retail
When you ask for support, remember to tell the bootloader you use :)
I am sorry, you shouldn't have replaced 0C with 01, my bad. 0C was correct for the kext Mirone provided, please retry it.
If it still doesn't work: from your codec dump some posts ago, you have an ALC271X. It has the same codec as ALC269 that's why Mirone sent you that kext, but anyway give this a try: http://www.insanelymac.com/forum/files/file/194-realtek-alc271x-applehda-audio/
The kext posted there requires your layout-id in DSDT to be changed to 1C.
Just to be sure, you have to take original AppleHDA.kext out of /System/Library/Extensions and then install the patched one.
271x is a step further. i got the sound working with up/down button volume control.
issues:
Recording on internal mic not working but I see it under system pref
Sounds is a little low (is there a way I can boost it?)
attached is my new DSDT
Thanks again!!!!
DSDT.new3.aml.zip
issues:
Thanks again!!!!
can someone help please!!!
Thank you so MUCH!!!!!!! The mic is working now. but I lost the up/down volume control. it's no longer workings. what should I look for?
Thanks again!!! i have tried everything out there and I couldn't figure it out. what was the issue if you don't mind?
Hello :)
Mavericks 10.9.1 on toshiba laptop here.
I used this code to patch my dsdt
Device (HDEF)
Name (_ADR, 0x001B0000)
OperationRegion (HDAR, PCI_Config, 0x4C, 0x10)
Field (HDAR, WordAcc, NoLock, Preserve)
DCKA, 1,
Offset (0x01),
DCKM, 1,
, 6,
DCKS, 1,
Offset (0x08),
, 15,
PMES, 1
Store (Package (0x16)
"AAPL,slot-name",
Buffer (0x09)
"built-in"
"codec-id",
Buffer (0x04)
0x69, 0x02, 0xEC, 0x10
"built-in",
Buffer (One)
0x00
"name",
Buffer (0x0F)
"Realtek ALC269"
"model",
Buffer (0x10)
"Realtek ALC271X"
"device-type",
Buffer (0x25)
"High Definition Audio Controller"
"layout-id",
Buffer (0x04)
0x1C, 0x00, 0x00, 0x00
"device_type",
Buffer (0x06)
"Sound"
"subsystem-vendor-id",
Buffer (0x04)
0x86, 0x80, 0x00, 0x00
"hda-gfx",
Buffer (0x0A)
"onboard-2"
Buffer (Zero) {}
}, Local0)
Return (Local0)
Method (_PRW, 0, NotSerialized)
Return (Package (0x02)
0x0D,
0x05
and this kexts taken from osx86
http://www.osx86.net/files/file/34-applehda-alc269-for-mavericks/
Internal speakers works but not headphones and mic
even if audio work I got lot of errors about AppleHDAController, logs attached.
(there are lot of other errors but for now I just to want to make audio works)
So.. about the layout-id.. where can I change it? In the dsdt? If I understood right, IORegistryExplorer take the layout-id from the DSDT right?
And if I change the layout-id, what id I've to put? Compared with what?
Hope that somebody could help me to make audio totally works
IOReg: http://www.sendspace.com/file/dbbbe4
Report.htm: report file from AIDA64 with all my laptop specs:
Report.htm.zip
Boot log:
log.log.zip
DSDT:
(I've tried to use Mirone DSDT in this post about 10.9
http://Olarila.com/forum/viewtopic.php?f=18&t=2734&start=20#p34263
but it doesn't work at all. I take only some parts of HDEF section of the DSDT attached there)
layout-id is applied to HDEF device inside _DSM method, in the DSDT. Check for the DSDT patches section: http://Olarila.com/forum/patches.php
You have to choose your layout-id according to the patched AppleHDA, this is the only thing to watch out. It varies on the taste of who made the patch. It could be 28 (1C), 12 (0C), 4, 1... Or even other numbers...
The kexts provided by Mirone always include a readme file telling you which layout-id to use.
