Hi
Im complete new in dsdt patching but i think its the only way to get a full working hackintosh on my Acer 5810tg
My Laptop is based on a ICH9m Chipset and there i can't find kext for mountain lion. So i wanna fake over a dsdt a ICH10 Chipset (I read that this works on mountain lion with Basic kext, am i right?)
So i extracted my DSDT with DSDT Editor and try the patches i found here... but that don't work... ive get the same EHCI and UHCI warnings like everytime... and the kext for the SMBus are not loaded too...
So what i have to do that it work? But please explain it that a noob like understand it :P
Thx
(Sry for my bad English)
Acer 5810 TG
Windows 8 Pro Media Center Edition
Mac OSX 10.8.2 Mountain Lion
Hi
Thx
Send me your dsdt.
Hi
sry for my late reply.... Here is my dsdt. it's newly extracted over windows. I patched my dsdt a little bit but i dont work right... so i send a complete new dsdt.
greets
Flo
DSDT.zip
Acer 5810 TG
Hi
greets
Flo
try this:DSDT.aml.zip
damn.... :))) how did you managed it to compile it without any errors, warnings or any other messages... :)))
i will i try it now :) Thank you so much :))))
Acer 5810 TG
okay... i made everything like you said but i get the same panic
i made a foto
thx :)
Acer 5810 TG
Hello,
try using current AppleACPIPlatform, you are using 1.3.5 which is Snow Leopard version.
Why are you using pmVersion=0 kernel flag? Are you using SleepEnabler?
Yes thats the reason why i use the old appleintelACPI...kext i thought it were from 10.8.1.
i read somewhere that sleepenabler works better with the old kext. hmmm okay then i try it with a newer one.
thx
Acer 5810 TG
okay then....
im back :P at first thank you all for your help :)))
okay... i have installed the original kext from the install-stick and i deleted the sleepenabler.kext.
After this steps mountain lion boot again. But now voodoobattery dont work :cry: .... and sleep dont work too....
i know that i have to use the ssdt to get a working sleep without sleepenabler. But my shitty laptop has 6 ssdt (over AIDA64).... I try it with the script in the post you linked... but then i get a 7 one... i try to merge all 6 together... (and i think it worked - no errors) but sleep will not work...
dsdt/ssdt patching is realy complicated... :oops:
Acer 5810 TG
okay then....
try this;DSDT.aml.zip
hmmm the same like the first one....
do i need to install patches from dsdt editor?
Acer 5810 TG
so same problem, sleep
u have a hack, not a mac, and some hacks the sleep don't work, is not only yours, is thousands , mine don't work too, black screen.
about ssdt , i think u don't read...
ssdt is only for sandy cpu, not u case
only need
p and c-states=yes
yeah i know but why is battery not working now?
is there a patch to use?
Acer 5810 TG
to battery works with voodoo battery, must use appleacpiplatform from snow leopard 10.6.7 or 10.6.8
http://www.osx86.net/downloads.php?do=file&id=1384
or see this
http://www.insanelymac.com/forum/topic/272459-appleacpibatterymanagerapplesmartbatterymanager-for-lion/
The problem with older AppleACPIPlatform started only after a DSDT patch? What did you change?
