Hi there,
I've installed ML using this image on my Dell Inspiron n7010 (specs listed below), the installation was successful, but, i have a problem with my graphic card, the os does not recognize it :(.
I'm using latest chimera bootloader version with this settings for vcard:
GraphicsEnabler=Yes, AtiConfig=Hoolock/Eulemur/..., AtiPorts=3
I cant reach desktop only if GraphicsEnabler is set to no :(
i've also tryed forced EDID, but no results (first boot i'v got 1152*864 then back to 1024*768)
Ethernet is working, no wifi, no sound also (voodoohda does recognize the device but no sound)
i really need your help guys.
P.S.1: I've tried some "kextes" but some times i get the same result as below and sometimes i get kernel panic.
P.S.2: the bootloader recognize the card, the framebuffer and the card family correctly (Ati 5470 1gb, Eulemur, Evegreen)
Laptop specs:
Intel Core i5 2.67Ghz
Memory: 4Gb
Graphics Card: ati mobility radeon hd 5470 1gb
Images in attachements describes how the screen looks like when i set GraphicsEnabler to Yes
Top Left corner:
Bottom right corner:
Whole screen:
try to use my file for forced edid is in my signature..
and see with system info > look for the app in forum downloads
see if it show also the intel hd.. if show intel hd + ati graphics card don't work at all
because the primary card is intel hd not supported in mac os x
thanks a lot for your help, graphic problem was solved using Forced EDID + this kext and using "Shrike" as framebuffer. For Audio, i used a dsdt patch combined with applehda kext.
every thing looks great except cmos reset for both mac os and windows.
