pernacabeluda Posted November 4, 2016 Author Posted November 4, 2016 Boot with the installer, open terminal (utilities menu) and rename AppleHPET from installed partition cd /Volumes/"your partition name"/System/Library/Extensions mv AppleHPET.kext AppleHPET.kext.orig Boot with -f and you should have working mouse. How to patch IRQs http://Olarila.com/forum/viewtopic.php?f=19&t=634 For networking you need to install proper kext http://Olarila.com/forum/viewtopic.php?f=28&t=1694 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
righN Posted November 4, 2016 Posted November 4, 2016 Boot with the installer, open terminal (utilities menu) and rename AppleHPET from installed partition cd /Volumes/"your partition name"/System/Library/Extensions mv AppleHPET.kext AppleHPET.kext.orig Boot with -f and you should have working mouse. How to patch IRQs http://Olarila.com/forum/viewtopic.php?f=19&t=634 For networking you need to install proper kext http://Olarila.com/forum/viewtopic.php?f=28&t=1694 Ok I managed to get my mouse and internet working but I can't manage bootloader to work. I installed it with Chameleon Wizard and when I'm trying to boot I get apple gray logo freeze when I tried to boot with -v -f I saw loading up kexts and then a black screen...
pernacabeluda Posted November 5, 2016 Author Posted November 5, 2016 Try to use same Chameleon version as in USB installer. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
righN Posted November 5, 2016 Posted November 5, 2016 Try to use same Chameleon version as in USB installer.I installed 2.1 r2069 not 2.1 r2109 which is on the USB because I couldn't find a working installer but that didin't fix the problem anyway. But in the start when I tried to boot it showed me that it can't find /mach_kernel but after some tries to boot it worked but I got black screen anyways.
pernacabeluda Posted November 6, 2016 Author Posted November 6, 2016 Try to copy boot file and Extra folder from USB to HD. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
righN Posted November 6, 2016 Posted November 6, 2016 Try to copy boot file and Extra folder from USB to HD.I only copied Extra folder because I couldn't find a boot file. But that didin't help, I used boot file from r2069 version and now everytime when I'm trying to boot it shows Can't find /mach_kernel.
pernacabeluda Posted November 6, 2016 Author Posted November 6, 2016 mach_kernel should be there, it's installed by default, I have no idea why it's not, you can copy from the installer. Both mach_kernel and boot files are hidden http://Olarila.com/forum/viewtopic.php?f=2&t=2919 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
righN Posted November 7, 2016 Posted November 7, 2016 mach_kernel should be there, it's installed by default, I have no idea why it's not, you can copy from the installer. Both mach_kernel and boot files are hidden http://Olarila.com/forum/viewtopic.php?f=2&t=2919 Yep, mach_kernel was there. I tried to use boot file from USB but it gave me this boot0: test boot0: test boot0: done boot1: error When I tried to use mach_kernel from the USB with boot file from r2069 version it gave me the same error Can't find /mach_kernel
pernacabeluda Posted November 7, 2016 Author Posted November 7, 2016 If you are using the installer from this topic, boot file is Clover, copy boot1 from USB and rename it to boot. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
righN Posted November 8, 2016 Posted November 8, 2016 If you are using the installer from this topic, boot file is Clover, copy boot1 from USB and rename it to boot. Yes I'm using installer from the topic, boot file worked but it still shows the same can't find /mach_kernel.
pernacabeluda Posted November 8, 2016 Author Posted November 8, 2016 Try this http://Olarila.com/forum/viewtopic.php?f=27&t=2899 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
righN Posted November 8, 2016 Posted November 8, 2016 Try thishttp://Olarila.com/forum/viewtopic.php?f=27&t=2899 I'm stuck at apple gray logo again... When booting in verbose mode after loading kexts I get black screen.
pernacabeluda Posted November 8, 2016 Author Posted November 8, 2016 Can you boot the installed system if you start from USB? Did you copy Extra folder from USB to HD? -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
righN Posted November 11, 2016 Posted November 11, 2016 Can you boot the installed system if you start from USB? Did you copy Extra folder from USB to HD? Uh, I forgot that I deleted it. Okay computers boots without problems now but now with those IRQs, I patched them, restored AppleHPET.kext but my mouse didin't work after restart. And another problem is with graphics, kext is installed but I can only use 1024x768 resolution and programs like Google Chrome are laggy.
pernacabeluda Posted November 14, 2016 Author Posted November 14, 2016 Make sure you have device HPET in DSDT and IRQs patch is applied. Put compiled DSDT.aml in /Extra. X3100 kexts are 32 bit only so you have to add arch=i386 to kernel flags. If your device ID is 2a12 you need to patch kexts http://Olarila.com/forum/viewtopic.php?f=3&t=144 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
righN Posted November 14, 2016 Posted November 14, 2016 Make sure you have device HPET in DSDT and IRQs patch is applied. Put compiled DSDT.aml in /Extra. X3100 kexts are 32 bit only so you have to add arch=i386 to kernel flags. If your device ID is 2a12 you need to patch kexts http://Olarila.com/forum/viewtopic.php?f=3&t=144 I added arch=i386 to the kernel flags, patched kexts because yes my device ID is 2a12. But that didin't help, maybe I used wrong kexts? And how to add device HPET to the DSDT?
pernacabeluda Posted November 14, 2016 Author Posted November 14, 2016 You should use original kexts, just run the commands to patch them and update caches sudo perl -pi -e 's|\x86\x80\x02\x2a|\x86\x80\x12\x2a|g' /System/Library/Extensions/AppleIntelGMAX3100FB.kext/AppleIntelGMAX3100FB sudo perl -pi -e 's|0x2A028086|0x2A128086|g' /System/Library/Extensions/AppleIntelGMAX3100FB.kext/Info.plist sudo perl -pi -e 's|\x86\x80\x02\x2a|\x86\x80\x12\x2a|g' /System/Library/Extensions/AppleIntelGMAX3100.kext/Contents/MacOS/AppleIntelGMAX3100 sudo perl -pi -e 's|0x2a028086|0x2a128086|g' /System/Library/Extensions/AppleIntelGMAX3100.kext/Contents/Info.plist sudo touch /System/Library/Extensions If there's no HPET in your DSDT, use this patch http://Olarila.com/Patches/Misc/New%20HPET.txt -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
righN Posted November 20, 2016 Posted November 20, 2016 You should use original kexts, just run the commands to patch them and update caches sudo perl -pi -e 's|\x86\x80\x02\x2a|\x86\x80\x12\x2a|g' /System/Library/Extensions/AppleIntelGMAX3100FB.kext/AppleIntelGMAX3100FB sudo perl -pi -e 's|0x2A028086|0x2A128086|g' /System/Library/Extensions/AppleIntelGMAX3100FB.kext/Info.plist sudo perl -pi -e 's|\x86\x80\x02\x2a|\x86\x80\x12\x2a|g' /System/Library/Extensions/AppleIntelGMAX3100.kext/Contents/MacOS/AppleIntelGMAX3100 sudo perl -pi -e 's|0x2a028086|0x2a128086|g' /System/Library/Extensions/AppleIntelGMAX3100.kext/Contents/Info.plist sudo touch /System/Library/Extensions If there's no HPET in your DSDT, use this patch http://Olarila.com/Patches/Misc/New%20HPET.txt I did that but it didin't help
faizalnin Posted October 3, 2018 Posted October 3, 2018 Hi, thanks for the guide. I have successfully installed the os on my dell inspiron 1525 using the boot option 1. I cannot load the os without usb. How do I change that to normal boot. There is no audio or WiFi connectivity also. Looking forward for your help.
going Posted October 1, 2019 Posted October 1, 2019 Mac OS X 10.6.3 Snow Leopard bootable USB for Intel PCs
dr.msnagi Posted March 8, 2020 Posted March 8, 2020 will this version work with dell latitude d531 ? it is an amd lap also needs superviaata.kext to recognize my sata hd and i knew this the hard way .....
Administrators MaLd0n Posted March 8, 2020 Administrators Posted March 8, 2020 8 hours ago, dr.msnagi said: will this version work with dell latitude d531 ? it is an amd lap no, u need change things inside image for put ur amd to boot -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
helper Posted May 30, 2020 Posted May 30, 2020 On 12/11/2012 at 10:05 PM, pernacabeluda said: It won't work on Pentium 4 with vanilla kernel, you need a legacy kernel. Replace mach_kernel in the pen drive by the one attached (using TransMac). legacy_kernel.zip 4.6 MB · 136 downloads just FYI - EXT 4 for mac can be read by windows (7zipped screen shot added) TBUSBDrive.7z
Gato Gordo Posted September 17, 2020 Posted September 17, 2020 Quote I can use it on a mac pro 2006 2.66 since I don't have the dvd reader thank you for your response
Administrators MaLd0n Posted September 17, 2020 Administrators Posted September 17, 2020 Yes use Option key and select installer -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
