pernacabeluda Posted October 31, 2012 Posted October 31, 2012 **The image is not a Distro, is a clean image without any mod with Clover bootloader, essentials kexts and patches, all inside Clover folder** --Download Updated Images https://www.olarila.com/forum/83-olarila-pre-made-iso-recommended/ --Unzip and Burn -Windows https://sourceforge.net/projects/win32diskimager/ -OS X diskutil list diskutil unmountDisk /dev/diskX sudo dd if=[arraste a imagem para o terminal] of=/dev/rdiskX bs=1m --Install Problems? You can press O or BarSpace key in Clover boot screen and change some configs for your hardware. -Credits and thanks to the old and new people in the community who developed patches, kexts and bootloaders! Slice, Kabyl, usr-sse2, jadran, Blackosx, dmazar, STLVNUB, pcj, apianti, JrCs, pene, FrodoKenny, skoczy, ycr.ru, Oscar09, xsmile, SoThOr, RehabMan, Download-Fritz, Zenit432, cecekpawon, Intel, Apple, Oracle, Chameleon Team, crazybirdy, Mieze, Mirone, Oldnapalm, netkas, Elconiglio, MaLd0n, artut-pt, ErmaC, Pavo, Toleda, Master Chief and family, bcc9, The King, PMheart, Sherlocks, Micky1979, vit9696, vandroiy2013, Voodoo Team, Pike R. Alpha, lvs1974, Austere.J, CVad, Badruzeus, JennyDavid, Sampath Kumar and many many others! We're all here to have fun and learn from each other! 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
weirdo77 Posted December 11, 2012 Posted December 11, 2012 When I boot from the USB, it always fails. If I use Clover, it says "loading drivers" with a bunch of dots, but after several lines of dots, the last couple of dots go blurry, and it restarts. If I use Chameleon, it reverts to text after loading all of the extensions, and just sits there.
pernacabeluda Posted December 11, 2012 Author Posted December 11, 2012 It won't work on Pentium 4 with vanilla kernel, you need a legacy kernel. Replace mach_kernel in the pen drive by the one attached (using TransMac). legacy_kernel.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
weirdo77 Posted December 11, 2012 Posted December 11, 2012 Thank you. By the way, I use linux so there is no program for transferring files. However, I found a way to transfer files to an hfs+ volume on linux. Where should I post how to do it?
pernacabeluda Posted December 11, 2012 Author Posted December 11, 2012 On Linux you can just dd the .raw file to /dev/sdX sudo dd if="Mac OS X 10.6.3 Install USB.raw" of=/dev/sdX Once it's done and mounted you can remount it as read/write sudo mount -o remount,rw,force /dev/sdX Then you'll be able to replace mach_kernel sudo mv "/media/Mac OS X Install USB/mach_kernel" "/media/Mac OS X Install USB/mach_kernel.orig" sudo cp mach_kernel "/media/Mac OS X Install USB" -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
weirdo77 Posted December 12, 2012 Posted December 12, 2012 dd doesn't work for me. I got SUSE Studio imagewriter on my centos box. Anyway, I finally got Snow Leopard installed with these boot options:"-x -v -f acpi=off PCIRootUID=0 GraphicsEnabler=No"(without quotes). However, when I boot from the installation, it fails. I've tried different combinations of boot options, but none of them seem to work.
pernacabeluda Posted December 12, 2012 Author Posted December 12, 2012 You need to replace mach_kernel also in the target partition. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
weirdo77 Posted December 12, 2012 Posted December 12, 2012 I got Snow Leopard installed successfully. Thanks. How do I install kexts? I got a kext for my NIC but I still don't have internet connectivity. I tried putting it in /Sytem/Library/Extensions and /Network, but that didn't work. Also, how do I install the bootloader?
pernacabeluda Posted December 12, 2012 Author Posted December 12, 2012 Post install instructions http://Olarila.com/forum/viewtopic.php?f=27&t=1716 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Richard Posted December 22, 2012 Posted December 22, 2012 Hi Sorry if this is an obvious question, using your post I have installed Snow Leopard on my netbook, but it won't boot from the HDD probably because I haven't installed the boot loader, so how exactly do you do it? I’m new to the Mac world although I have had some experience with UNIX. Just for info SUSE didn’t work but the second option did also Clover didn’t work but Chameleon did Richard
pernacabeluda Posted December 22, 2012 Author Posted December 22, 2012 Hi, look my previous post Post install instructions http://Olarila.com/forum/viewtopic.php?f=27&t=1716 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Seusan Posted January 12, 2013 Posted January 12, 2013 I've had nothing but trouble trying to install this OS on ANY machine I own, multiple ways with legit and not so legit copies of OS X, NOTHING I did worked. Until I found this post. Heere is a collection of my edits to the post as I went figuring things out for myself as I think this thread is dead... anyway incase someone like me stumbles across it, here ya go: Hi thanks for the post, I've been trying install on an inspiron 1525 for a week and your post is the farthest I've gotten. I've ran into issues though. I couldn't use SUSE to copy the .raw to my USB because of an "exception error" so I used "Image Writer" instead (https://launchpad.net/win32-image-writer/+download), I tried the boot and it cut out just before the installer screen I got that os x gray colour then it was black. I'm having trouble trying the kexts fix, through TransMac what I get is: (also see pic attached) HFS+ Extra Install Mac OS X.app Instructions.localized Optional Installs.localized I'm new to Mac can't find/don't know how to browse the "(System/Library/Extensions) and delete Extensions.mkext (System/Library/Caches/com.apple.kext.caches/Startup)" you mentioned. Also tried to input this code but again dunno when or where or how to start the prompt to do so: fsck -fy mount -uw / mkdir /kext_backup cd /System/Library/Extensions mv AppleIntelIntegrated* AppleIntelGMA* ATI* GeForce* NVDA* /kext_backup rm ../Caches/com.apple.kext.caches/Startup/Extensions.mkext reboot Think you could help me out or tell me where I'm going wrong?? ========================================================================================================================================= It's show hidden files in TransMac Options > Show Hidden Files, I'll report back if it works. OK!! I will update this as I go incase someone else having trouble stumbles across it having never used the software I deleted ALL of the files containing: AppleIntelIntegrated and AppleIntelGMA in their names. You will have to go into a "mac" or "contents" subfolder when trying to find some of them. Extensions.mkexts located in the cache directory path "System/Library/Caches/com.apple.kext.caches/Startup" My installation screen popped right up. I'm sure I'll have a million other issues as I've been at this for a week! but I will update as I go. Ok, After install completes boot back to USB drive but as it's starting tap '1' on the keyboard to launch Chameleon boot loader because the HDD you just installed to will not show up in Clover. Proceed to this link http://Olarila.com/forum/viewtopic.php?f=27&t=1716 to install boot loader to HDD and then install kexts as you need them. I will update as I go.
Kimo_13 Posted March 9, 2013 Posted March 9, 2013 When I boot from the USB, it always fails.If I use Clover, it says "loading drivers" with a bunch of dots, but after several lines of dots, the last couple of dots go blurry, and it restarts. If I use Chameleon, it reverts to text after loading all of the extensions, and just sits there. Same Problem but I've a Pentium P6200 Laptop Acer Aspire 5742z Any Ideas? Device 1 : Acer Aspire 5742z 2 GB RAM 320 GB HDD Intel HD Graphics Mac OS X Lion or SL. Device 2 : Chiligreen Platin MJ 4 GB RAM 750 GB HDD Intel HD Graphics Windows 8 Pro 64bit I need a Driver for Netgear WG111 for Lion or Mountain Lion.
Deviance Posted April 20, 2013 Posted April 20, 2013 I got DSMOS HAS ARRIVED on my acer AO751H, any solution?
peterbob Posted April 20, 2013 Posted April 20, 2013 I managed to install and now I am booting using the USB thumdrive. I need to know to install the bootloader/clover to the HD from the USB image. I am using the torrent indicated on the OP. I have looked up the post install instructions, it says to install clover but its are not clear as to how to do this. Should I just move the Extra or the Boot directory to the HD? thanks, peter BTW: I dont think I am using the UEFI mode option. I used the first boot option from the USB to boot and install, and now I am using the boot from HD option.
artur-pt Posted April 21, 2013 Posted April 21, 2013 hello sure u don't read the post .... install with the pkg if u don't know nothing about the loader .... see the links ... and read all about Clover. good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
ericsia Posted February 15, 2014 Posted February 15, 2014 can i ask? which version of clover that you use? you still remember? GMA 4500 kext https://mega.co.nz/#!DlIQ2CpA!OovTWWRQIUQ-osUbj7bcTjrbByBCmVf5AfW-A5GUNtA
FireWire786 Posted July 18, 2015 Posted July 18, 2015 I Need help,you said i need to delete Extensions.mkext on the USB and i did that but it keep telling me "An unexpected error is keeping you from deleting the folder."
pratiklad Posted August 1, 2015 Posted August 1, 2015 sir even i have a problem with the deletion of the things in usb bootable 10.6.3 .it is not showing installation screen
sanshiro21 Posted January 12, 2016 Posted January 12, 2016 I cant find the link, can anyone help me please
mendietinha Posted January 12, 2016 Posted January 12, 2016 Access chat to get download link (channel topic). first thing you will see is a welcome and a pastebin link. Se quando viaja faz o que quer, quando viajar, não leve a mulher ---- No PM support. Use the forum. . Lenovo Core I5 6200U 12Gb 256Gb HD520 (macOS 13.7.6 - macOS 26) OC Ryzen 7 5700X 32Gb 2Tb nvme RTX 3060TI 8Gb (W11)
righN Posted November 3, 2016 Posted November 3, 2016 Hi, I'm trying to install Snow Leopard on my HP Compaq 6720s. I made bootable USB, but I have problems when I'm trying to install Mac OS X. With Clover (tried bootflags like GraphicsEnabler=No, USBBusFix=Yes, -f, -x didin't help) : With Chameleon (tried bootflags like USBBusFix=Yes, USBLegacyOff=Yes, -x didin't help):
pernacabeluda Posted November 3, 2016 Author Posted November 3, 2016 Try to move AppleHPET.kext from /System/Library/Extensions and boot with -f If it works, patch IRQs in device HPET in DSDT and restore the kext http://Olarila.com/Patches/Misc/IRQs.txt -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
righN Posted November 4, 2016 Posted November 4, 2016 Try to move AppleHPET.kext from /System/Library/Extensions and boot with -f If it works, patch IRQs in device HPET in DSDT and restore the kext http://Olarila.com/Patches/Misc/IRQs.txt Okay, I installed Mac OS X when deleted AppleHPET.kext but I didin't patched IRQ because I didin't know how and now my USB mouse isn't working and I don't have internet on my computer :/
