pernacabeluda Posted July 30, 2014 Posted July 30, 2014 Com certeza não é. A original tem todos estes layout0.xml.zlib layout31.xml.zlib layout7.xml.zlib layout1.xml.zlib layout32.xml.zlib layout70.xml.zlib layout10.xml.zlib layout33.xml.zlib layout71.xml.zlib layout100.xml.zlib layout35.xml.zlib layout72.xml.zlib layout107.xml.zlib layout36.xml.zlib layout73.xml.zlib layout108.xml.zlib layout38.xml.zlib layout74.xml.zlib layout11.xml.zlib layout39.xml.zlib layout75.xml.zlib layout113.xml.zlib layout4.xml.zlib layout76.xml.zlib layout114.xml.zlib layout40.xml.zlib layout77.xml.zlib layout12.xml.zlib layout42.xml.zlib layout78.xml.zlib layout120.xml.zlib layout44.xml.zlib layout79.xml.zlib layout121.xml.zlib layout46.xml.zlib layout80.xml.zlib layout122.xml.zlib layout48.xml.zlib layout81.xml.zlib layout123.xml.zlib layout5.xml.zlib layout82.xml.zlib layout124.xml.zlib layout50.xml.zlib layout83.xml.zlib layout13.xml.zlib layout53.xml.zlib layout84.xml.zlib layout16392.xml.zlib layout56.xml.zlib layout85.xml.zlib layout16394.xml.zlib layout58.xml.zlib layout86.xml.zlib layout17.xml.zlib layout59.xml.zlib layout88.xml.zlib layout18.xml.zlib layout6.xml.zlib layout9.xml.zlib layout19.xml.zlib layout60.xml.zlib layout90.xml.zlib layout2.xml.zlib layout61.xml.zlib layout91.xml.zlib layout20.xml.zlib layout62.xml.zlib layout92.xml.zlib layout21.xml.zlib layout63.xml.zlib layout93.xml.zlib layout24.xml.zlib layout64.xml.zlib layout94.xml.zlib layout27.xml.zlib layout65.xml.zlib layout95.xml.zlib layout28.xml.zlib layout66.xml.zlib layout98.xml.zlib layout29.xml.zlib layout67.xml.zlib layout99.xml.zlib layout3.xml.zlib layout69.xml.zlib https://www.sendspace.com/file/wuko0k -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
RCOO Posted July 30, 2014 Posted July 30, 2014 Podes mandar-me a AppleHDA original do DP4 então? Isto é, se tiveres.
pernacabeluda Posted July 30, 2014 Posted July 30, 2014 Está no post anterior (link sendspace). Uma sugestão, aqui tem 2 patches para ALC269 http://Olarila.com/files/10.9/Audio/AppleHDAPatcher/Patches/Laptop/ Você pode começar por um deles, modificar os arquivos platforms, layout e hdaconfig de acordo com o seu codec dump, depois usar o AppleHDAPatcher http://Olarila.com/forum/viewtopic.php?f=9&t=4487 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
RCOO Posted July 30, 2014 Posted July 30, 2014 O meu principal problema é q não consigo perceber como funcionam os paths e como são inseridos na platform.xml! O patch já trata disso?
pernacabeluda Posted July 30, 2014 Posted July 30, 2014 Não, isso você precisa fazer. Está tudo no guia, tem até imagens mostrando. Tem que usar o PlistEdit Pro, senão fica complicado de visualizar mesmo. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
RCOO Posted July 30, 2014 Posted July 30, 2014 Mas, por exemplo, não diz no guia quando devemos usar as chaves AMP e BOOST... Cada path é um neto do primeiro elemento do pathmap? Quando vejo o meu SVG vejo muitos caminhos possíveis.
pernacabeluda Posted July 30, 2014 Posted July 30, 2014 Acho que o Mirone pode te explicar melhor isso, aguarda por uma resposta dele. Por isso eu sugeri começar a partir de um daqueles patches para ALC269, os arquivos estão prontos, você só precisa editar os números dos nodes. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
RCOO Posted July 30, 2014 Posted July 30, 2014 Estou a tentar aplicar o patch, uma vez que os dados da platforms.plist coincidem com os meus paths... No entanto, não consigo aplicar o patch-hda: "Unexpected codec match count: 2 (4 expected) Aborting with AppleHDA NOT patched" Penso que seja porque estou a usar o yosemite?
pernacabeluda Posted July 30, 2014 Posted July 30, 2014 Não sei te dizer. Usei o AppleHDAPatcher no Yosemite e funcionou. Ele já faz o binpatch, não precisa usar ele e depois rodar o binpatch do guia. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
RCOO Posted July 30, 2014 Posted July 30, 2014 Eu usei esse primeiro, mas o arquivo AppleHDA depois de dizer que teve sucesso não parecia ter modificações (a data de modificação nem coincidia). Então fiz as alterações manualmente e usei o bin patch daqui http://www.insanelymac.com/forum/topic/284004-script-to-patch-applehda-binary-for-osx107108109/.
pernacabeluda Posted July 30, 2014 Posted July 30, 2014 Em AppleHDAPatcher.app/Contents/Resources deve existir uma kext AppleHDA original atualizada. Se você não colocar a do DP4 ele vai criar com a do 10.9.4 que já está lá. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
RCOO Posted July 30, 2014 Posted July 30, 2014 Espera. Acho que encontrei. Ele cria um zip na pasta onde fica a app do patch, certo? Acho que estava a ver no sítio errado. Vou tentar esse novo zip. Ok. Instalei o kext resultado do patch. Fiz a edição do DSDT, para alterar o layout para 1 e nada sem som :s
pernacabeluda Posted July 30, 2014 Posted July 30, 2014 Então os nodes e pathmaps não devem ser exatamente iguais. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
RCOO Posted July 31, 2014 Posted July 31, 2014 Vou tentar os kexts desse post: http://www.insanelymac.com/forum/topic/298663-applehda-for-yosemite-dps/ Não funcionaram... Deixei lá os meus ficheiros e vou esperar que o Mirone dê uma olhada. O Mirone conseguiu resolver. Fica aqui a solução em anexo. Não esquecer de editar o DSDT para definir o layout 3. http://cl.ly/411G1D2i0Y0n
pernacabeluda Posted July 31, 2014 Posted July 31, 2014 Seria bom informar o modelo do laptop, pois como você deve ter percebido o codec ALC269 tem muitas variações, dificilmente vai servir para um laptop diferente. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
uzmi Posted October 15, 2014 Posted October 15, 2014 Corrigido o script Toleda obrigado Olá: Eu tento criar meu AppleHDA.kext personalizado (Mavericks 10.9.5 placa GA P43T ES3G). Eu estou preso em esta etapa: Eu recebo o seguinte e verbs modificados são incompletos: invalid number0: printf: 0x10ec0892 Use graphviz-2.39.20141014.0445.pkg Anexo meus arquivos: Muito obrigado Eu não falo Português por isso, desculpa a minha gramática. P43T ES3G.zip I5 9600K - Ga Z390M Gaming -Shappire RX 580 4Gb - DDR4 16gB- Big Sur Open core
Maf3r0 Posted November 23, 2014 Posted November 23, 2014 Olá, me tira uma dúvida… Um dos procedimentos do codec verb é desativar determinados nodes. Esse processo é realmente obrigatório? Tipo, se eu não desativá-los, a ativação do áudio pode ser comprometida ou desativa-se apenas para deixar a kext mais "original"? Outra coisa, o EAPD ainda é necessário? Ele não está presente em nenhuma kext funcional que analisei. Obrigado. iMac 19,2 (10.15.4) + Win 10 @ OpenCore UEFI Dual Boot H310M-S2P | i3 8100 | 16GB DDR4 | UHD 630 + RX 580 (PowerColor) | ALC887 | Realtek RTL8118 | TP-Link WN781ND
mgmlrl Posted December 21, 2014 Posted December 21, 2014 Estou pedindo esta ajuda para ter áudio no meu hack pois não sei o que está errado com ele. Em “Informações do sistema”, é mostrado “ID do Audio:1”. Na HDEF, o layout_id aparece como “ 0x01, 0x00, 0x00, 0x00 “, que pelo que entendi do que pesquisei, corresponde a ID de audio mostrada pelas “Informações do Sistema” Pelo que entendi, era para o áudio estar funcionando, pois o layout_id que está na HDEF corresponde a ID de áudio mostrada pelas “Informações do sistema”. Não tenho instalada a VoodooHDA e nem nenhuma HDAEnabler. Meu boot.plist não tem nem a flag npci=0x2000 e nem a flag npci=0x3000. O codec de áudio da placa-mãe é o Realtek ALC898. Alguém pode me dizer o que está errado ou o que está faltando para o áudio do meu hack funcionar ? Não sei o que fazer para corrigir o problema, pois pelo que pesquisei era para o áudio estar funcionando. Agradeço pela ajuda. Abaixo está a HDEF e a configuração do meu hack está na assinatura. Device (HDEF) { Name (_ADR, 0x001B0000) Method (_DSM, 4, NotSerialized) { Store (Package (0x04) { "layout-id", Buffer (0x04) { 0x01, 0x00, 0x00, 0x00 }, "PinConfigurations", Buffer (Zero) {} }, Local0) DTGP (Arg0, Arg1, Arg2, Arg3, RefOf (Local0)) Return (Local0) } OperationRegion (HDAR, PCI_Config, 0x4C, 0x10) Field (HDAR, WordAcc, NoLock, Preserve) { DCKA, 1, Offset (0x01), DCKM, 1, , 6, DCKS, 1, Offset (0x08), , 15, PMES, 1 } Obrigado pela atenção Placa-mãe Gigabyte GA-Z77X-UP5-TH, processador I7-3770K, placa de vídeo MSI GTX 660TI, 8 GB RAM, 2 HDs 1 TB, bootloader Chameleon, Windows 7 em um HD e Mountain Lion 10.8.5 no outro
Rody Nunes Posted October 22, 2015 Posted October 22, 2015 Olá pessoal Estou tendo dificuldade enorme em resolver o áudio do El Capitan em minha WorkStation. Instalei o Linux extrai o codec_dump, useu o codecgraph depois o convert hex to dec e por fim o verbit, o resultado do verbit saiu isso tudo: Verbs from Linux Codec Dump File: codec_dump.txt Codec: Realtek ALC889 Address: 2 DevID: 283904137 (0x10ec0889) Jack Color Description Node PinDefault Original Verbs -------------------------------------------------------------------------------------------------------- ATAPI Unknown SPDIF Out at Int ATAPI______17 0x11 0x99430140 21171c40 21171d01 21171e43 21171f99 1/8 Black Speaker at Ext Rear_________18 0x12 0x411111f0 21271cf0 21271d11 21271e11 21271f41 1/8 Green Line Out at Ext Rear________20 0x14 0x01014410 21471c10 21471d44 21471e01 21471f01 1/8 Black Line Out at Ext Rear________21 0x15 0x01011412 21571c12 21571d14 21571e01 21571f01 Line Out at Ext Rear______0x16 0x16 16868369 21671c11 21671d64 21671e01 21671f01 1/8 Grey Line Out at Ext Rear________23 0x17 0x01012414 21771c14 21771d24 21771e01 21771f01 Mic at Ext Rear___________0x18 0x18 27368528 21871c50 21871d9c 21871ea1 21871f01 Mic at Ext Front__________0x19 0x19 44145760 21971c60 21971d9c 21971ea1 21971f02 Line In at Ext Rear_______0x1a 0x1a 25244767 21a71c5f 21a71d34 21a71e81 21a71f01 HP Out at Ext Front_______0x1b 0x1b 35736608 21b71c20 21b71d4c 21b71e21 21b71f02 ATAPI Unknown CD at Int ATAPI_____________28 0x1c 0x593301f0 21c71cf0 21c71d01 21c71e33 21c71f59 Optical White Line Out at Ext N/A_________29 0x1d 0x4005e601 21d71c01 21d71de6 21d71e05 21d71f40 Comb Orange SPDIF Out at Ext Rear_______30 0x1e 0x014b6130 21e71c30 21e71d61 21e71e4b 21e71f01 Comb Yellow SPDIF In at Ext Rear________31 0x1f 0x01cb7170 21f71c70 21f71d71 21f71ecb 21f71f01 -------------------------------------------------------------------------------------------------------- Jack Color Description Node PinDefault Modified Verbs -------------------------------------------------------------------------------------------------------- ATAPI Unknown SPDIF Out at Int ATAPI______17 0x11 0x99430140 21171c40 21171d00 21171e43 21171f90 1/8 Green Line Out at Ext Rear________20 0x14 0x01014410 21471c10 21471d40 21471e01 21471f01 1/8 Black Line Out at Ext Rear________21 0x15 0x01011412 21571c80 21571d10 21571e01 21571f01 Line Out at Ext Rear___________0x16 0x16 16868369 21671c90 21671d60 21671e01 21671f01 1/8 Grey Line Out at Ext Rear________23 0x17 0x01012414 21771ca0 21771d20 21771e01 21771f01 Mic at Ext Rear___________0x18 0x18 27368528 21871c50 21871d90 21871ea1 21871f01 Mic at Ext Front__________0x19 0x19 44145760 21971c60 21971d90 21971ea1 21971f01 Line In at Ext Rear_______0x1a 0x1a 25244767 21a71cb0 21a71d30 21a71e81 21a71f01 HP Out at Ext Front_______0x1b 0x1b 35736608 21b71c20 21b71d40 21b71e21 21b71f01 Optical White Line Out at Ext N/A_________29 0x1d 0x4005e601 21d71cc0 21d71de0 21d71e05 21d71f40 Comb Orange SPDIF Out at Ext Rear________0 0x1e 0x014b6130 21e71c30 21e71d60 21e71e4b 21e71f01 Comb Yellow SPDIF In at Ext Rear________31 0x1f 0x01cb7170 21f71c70 21f71d70 21f71ecb 21f71f01 -------------------------------------------------------------------------------------------------------- As conexões traseira da torre olhando de frente pra ela da esquerda para direita CINZA PRETO LARANJA ROSA VERDE AZUL Na frente da torre ROSA VERDE Tenho que mudar algo no resultado acima? Quais desse monte de número do resultado é o ConfigData/Verbs? Estou completamente perdido na hora de inserir os dados dentro da kext. Agradeço
