HI, i've changed my graphic card, and now i get the error "Pci configuration begin" and my pc hang up.
I've lion 10.7.4 and now i've gtx 550 ti (before with gt 8800 512 oc and hd 5770 works perfectly)
any suggestion??? thanks
Lion 10.8.4, q6600 - p5e3 deluxe GTX 550 ti 1 gb - 8 gb ddr3 corsair 1600
try to see
with
PCIRootUID=1
insert in boot
or npci=0x2000
Hi, i used before : -v arch=i386 npci=0x2000
and i try to replace AppleACPIPlatform and IOPCIFamily from 10.6.7, the situatio (in both tests) is:
but i've an IR MOUSE.
one single thing
why are u using a installer ?
after i replace my graphics card, my lion 10.7.4 did't work( it hangs on apple logo).
i've a time machine backup than i prefer to start from installer, reinstall os lion and with migration assistant replace everything.
The installer is the one that i use a lot of time with a lot of PC's. It worked with gt 8800 and several ATI Cards.... no problem.
But now I'm finding issue with my gtx 550 ti. if i put again my 8800 the installer stars.
I'll try with ML INSTALLER.... and i cross my fingers... Thanks 4 your support
