I will admit that I am not in the know about these DSDT files and what they are, but I am told that I need one.
I am trying to get the Mac OS onto my computer so that I can figure it out and decide if I want to by a REAL MBP as they are rather expensive.
I have downloaded your DSDTparser.jar and am running it in my win7 install (as I am having problems getting much to run on Mac10.6. There is no patch file that I can find for the P8B75M motherboard. I have firmware 812 installed. I did get the P8 generic patch and it runs, but when I compile I get 143 errors and 1 warning.
HELP!
Do I need to get some fixed patch file to make my motherboard work?
Am I getting all these errors because I am not using the right patches?
what do I need to read or do to get this to work. I am willing to put in what is needed to learn, but I need some help finding the way there.
Matt.
to install mac os x , u don't need dsdt, it help after the installation to work, but is not indispensable
Well. I think in my case I do. I can get the Snow Leopard to load, but end up with I can use the mouse, but the keyboard seems to stop working after several minutes. I have no network, and can't set the screen resolution.
I did some more searching and decided to give the P8-3k patch a try and that worked. So I think that I have the DSDT.aml file made. But no clue on what I do with it to get some of the other bits working better. Any help is appreciated.
M.
