Hi All,
I have been able to install onto my test drive Monterey Beta 4.  System is a Asus z390 prime a intel i9 9900k 64gb ram sapphire 5700xt nitro various drives.  All using open core 0.7.1 with latest kexts.
On Big Sur the system is flawless and I understand issues are to be expected with beta but wondered if any of you had come across them.
Issue 1 is that upon boot on my desktop the windows hard drive shows.  External Drives and Hard Drives are unticked in sys preferences and as such I wouldn't expect it to show and it doesn't in Big Sur.  Is there a fix for this?
Issue 2 that is more of a problem is that after leaving the system to sleep for a while it will wake to black screen and the only way to resolve this is to restart the machine.
Any help resolving these issues would be great
Matt
Hi Maldon,
Thanks for the help and sorry for the delay in coming back to you have been away.  Here is the ioreg dump.  The file is on 3mb so won't allow me to drag and drop hopefully this dropbox link works.
https://www.dropbox.com/s/yfp8p8wf7m3ciwi/Send%20me%20Matthews-iMac.zip?dl=0
first remap usb 2. HSxx ports
and after USB 3. SSxx ports
That’s what I did and after I excluded some of the ss ports that did not work I restarted as the guide said and more showed up with different numbers
Each time more come up do I just keep adding the ones that don’t work to the exclude list till no more show
pay attention
procedure is same for all
I have tried multiple times to follow the guide and complete the usb mapping and I can not get it to work.  Is there anyone who has successfully done this on a Asus prim a z390 board who would kindly let me have the file needed.  I also can not get the computer to sleep and believe this is the cause.  I am really struggling to sort this and would appreciate any help and of course happy to send some money across PayPal
u need work with limit ports. u have a 15 ports. in many cases we need kill some ports for stay in this limit
