Hello, guys!
My system:
Mac OS X 10.8.2
Asus Rampage III Extreme
i7 950 3.07 Ghz
2x nVidia GTX 470 (SLI in Win7)
ALC 889 - multishit
DSDT (patched with DSDT Editor - no errors, no warnings)
only kexts installed: AACPIPlatform Rollback, FakeSMC, patched 10.7.4 AppleHDA.kext
Everything is OK and works, except sleep:
I removed the prw method of usb in dsdt, now the usb wake ok.
System wake up to 99% ...
The system goes into auto-sleep only: darkwake=0.
HWMonitor bar shows 12% cpu speedstep ...
The mouse moves, keyboard ok, but Pointer remains rainbow wheel ...?
I do not know if it is an issue with cpu (speedstep) or a missing patch in dsdt ...
Attached my DSDT.aml below
I would appreciate some advice ...
Thanks!
Asus M12F - i9 10900k - RAM 32GB - RX5700XT SE Nitro+ 8GB - BS 11.1
I don't understand that part. Refer to this link http://Olarila.com/forum/viewtopic.php?f=19&t=634
No powermanagement = no sleep. Attach the untouched DSDT.
Sorry, probably my bad english.
System goes to sleep well with Stop in apple menù, and auto sleep working properly with darkwake=no in org.chameleon.
The principal problem is wake. Because monitor, usb (keyboard, mouse, etc..) and sata disk turns on, but The system freezing. I have to restart by pressing reset.
For powermanagement, in console i have:
kernel[0]: AppleIntelCPUPowerManagement: Turbo Ratios 1112
kernel[0]: AppleIntelCPUPowerManagement: (built 23:03:24 Jun 24 2012) initialization complete
kernel[0]: AppleIntelCPUPowerManagementClient: ready
In dsdt i removed _PRW method from: UHC & EHCI, and now usb wake on, but I have this in console:
[0xffffff801990f400] The IOUSBFamily is having trouble enumerating a USB device that has been plugged in. It will keep retrying. (Port 2 of Hub at 0x1a000000)
[0xffffff801990f400] The IOUSBFamily was not able to enumerate a device.
For wake reason:
kernel[0]: Wake reason =
kernel[0]: USB (EHCI):Port 2 on bus 0xfa connected or disconnected: portSC(0x101803)
kernel[0]: An Unknown USB Device (Port 2 of Hub at 0x1a000000), may have caused a wake by being connected
The link you posted...
I tried to follow yet...
My untouched DSDT:
Rampage III Extreme.dsl.zip
Thanks in advance pmdsp!
I discovered that the freeze after wake (main problem) are related precisely to wake up the sata disks... USB and LAN wake up properly...
DSDT patch?
