Hi, i'm writing this post because i've have a mistery issue.
My Hackintosh worked perfectly for 6 month (lion 10.7.4) (p5e3 deluxe, q6600 gt 8800 512 oc, ssd agility 3).
3 days ago a found a strange problem... when i sturtup my system it load, but in the end before see my desktop (after apple logo) my monitor seem to go in sleep.
I'did.t nothing. any suggestion??? maybe i should get in Touch with "detective sheridan".... :-)
Im tring to add ketxt in extra folder one to one.......'
Lion 10.8.4, q6600 - p5e3 deluxe GTX 550 ti 1 gb - 8 gb ddr3 corsair 1600
hi
try to boot
-v
another thing lion use kernel cache to accelerate the boot process
so don't use Extra/Extension it can boot also using that, but every time it boot read all the kext
post a photo of the boot using -v
also the kext u use , u don't belong to the system
849006321_Schermata09-2456186alle14_45_11.png.60b0c5cc6f9dcd0f51b6d0a377428f46.pngI can't boot with -v because in chamaleon i selected to boot directly..... anyway a find the issue... are kext of my gt 8800.
i don't know why because for 6 month until 3 days ago they worked fine.
maybe i've to enable my vnidia card following the instruction oF OLDPAM.
iìll post my extention folder
I solved..... :shock:
After 10 time to reinstall the system and restore time machine back...... delete and reinstall the next............. the mistery was......... Bho?????
Anyway i pulled my ddr memory, take off power, mount my memory and magically my grafics card worked as before °(whit the same kets)
i Don't know why!!!
Update.......
The problem rise again...... than.....
i removed NVinjectGo.kext installed chamaleon 755 (before was 752).... and now work perfect.
I don't know why until tree day ago it worked for 6 month with chamaleon 752 and NVinjectGo.kext!!! Mistery
The problem come back!!! I'm going cracy, may be i'll try e clear installation!!!
Solved! The problem was my grafic card. A really strange beavour.
How can i mark topic as SOLVED?????
