Hackintosh OpenCore Vanilla Guide - Easy way to build Vanilla Hackintosh
-Problems with Paypal HERE
-Installation Guide HERE
-Hackintosh EFI folders HERE
-Hackintosh USB Remap HERE
-Why Olarila doesn't support TonyMac, Reedit, Little-Translated and others HERE
--Sky Lake and Kaby Lake
Intel® Core™ i7-6785R, i7-6700T, i7-6700, i7-6700K, i5-6585R, i5-6685R, i5-6402P, i5-6500T, i5-6500, i5-6600T, i5-6400, i5-6400T, i5-6600, i5-6600K, i3-6098P, i3-6300, i3-6320, i3-6100T, i3-6300T, i3-6100, i7-7700T, i7-7700, i7-7700K, i5-7500T, i5-7500, i5-7600K, i5-7400, i5-7600, i5-7600T, i5-7400T, i3-7350K, i3-7320, i3-7100T, i3-7101TE, i3-7100, i3-7300T, i3-7300, i3-7101E
--Coffee Lake and Comet Lake
Intel® Core™ i9-9900KS, i9-9900T, i9-9900, i9-9900KF, i9-9900K, i7-9700T, i7-9700, i7-9700F, i7-9700KF, i7-9700K, i5-9600T, i5-9500T, i5-9500F, i5-9600, i5-9400T, i5-9500, i5-9400, i5-9400F, i5-9600KF, i5-9600K, i3-9100F, i3-9320, i3-9350K, i3-9100, i3-9100T, i3-9300, i3-9300T, i3-9350KF, i7-8086K, i7+8700, i7-8700T, i7-8700K, i7-8700, i5+8500, i5+8400, i5-8500T, i5-8600, i5-8600T, i5-8500, i5-8400T, i5-8600K, i5-8400, i3-8300, i3-8300T, i3-8100T, i3-8100, i3-8350K, i9-10850K, i9-10900T, i9-10900, i9-10900F, i9-10900KF, i9-10900K, i7-10700F, i7-10700KF, i7-10700K, i7-10700T, i7-10700, i5-10505, i5-10600K, i5-10600KF, i5-10600T, i5-10500T, i5-10400T, i5-10500, i5-10400F, i5-10400, i5-10600, i3-10105F, i3-10325, i3-10105T, i3-10305T, i3-10305, i3-10105, i3-10100F, i3-10320, i3-10300, i3-10300T, i3-10100, i3-10100T
--Rocket Lake
Intel® Core™ i9-11900KF i9-11900K i9-11900 i9-11900F i9-11900T i7-11700K i7-11700KF i7-11700 i7-11700F i7-11700T i5-11400F i5-11500T i5-11400T i5-11600 i5-11400 i5-11600K i5-11600KF i5-11500 i5-11600T
--Alder Lake and Raptor Lake
Intel® Core™ i9-12900KS i9-12900 i9-12900F i9-12900T i9-12900K i9-12900KF i7-12700F i7-12700T i7-12700 i7-12700K i7-12700KF i5-12400F i5-12400 i5-12400T i5-12500 i5-12600 i5-12500T i5-12600T i5-12600K i5-12600KF i3-12100F i3-12100 i3-12300 i3-12300T i3-12100T, i9-14900KS, i9-14900F, i9-14900, i9-14900T, i9-14900K, i9-14900KF, i7-14700F, i7-14700T, i7-14700, i7-14700KF, i7-14700K, i5-14500T, i5-14600, i5-14400T, i5-14400, i5-14500, i5-14600T, i5-14400F, i5-14600K, i5-14600KF, i3-14100F, i3-14100, i3-14100T, i9-13900KS, i9-13900F, i9-13900T, i9-13900, i9-13900K, i9-13900KF, i7-13700, i7-13700F, i7-13700T, i7-13700K, i7-13700KF, i5-13500, i5-13600T, i5-13600, i5-13400F, i5-13400, i5-13400T, i5-13500T, i5-13600K, i5-13600KF, i3-13100, i3-13100F, i3-13100T
Some Basic Information
-Bios/UEFI configuration check HERE
-If you have only IGPU use -igfxvesa bootarg for easy installation
-Reset NVRAM one time - OpenCore use entry "Reset Nvram" / Clover use F11 key on boot screen
a) If you used SSDT instead DSDT uncheck RebaseRegions in Acpi tab
b) You can request one full ACPI solution HERE and Premium Users HERE
c) After installation you need remove unnecessary files like unused Lan kexts
d) Remove agdpmod=pikera bootarg if you have RX550, RX560, RX570 and RX580
e) If your LAN card don't need dk.e1000=0 and e1000=0, remove these bootargs
f) Users with IGPU need change SMBIOS and create video patch
Step 1 - Downloading Olarila Vanilla Images or Create one Vanilla USB Installer
1a) Olarila Images (Windows, Mac or Linux) HERE
1b) How to create USB Installer (Mac) HERE
Step 2 - Burning Olarila Images with Balena Etcher with Windows, macOS or Linux
2a) Download Link HERE
Step 3 - Downloading correct EFI folder for your hardware with Clover or OpenCore
3a) OpenCore and Clover HERE
3b) OpenCore MOD HERE
Step 4 - Copying EFI folder to USB EFI partition with macOS or Windows HERE
Step 5 - Formatting SSD on Installer
5a) On Disk Utility Change "View" options to "Show All Devices"
5b) Selecting and formatting SSD. Use GUID and APFS
Step 6 - Copying EFI folder to SSD EFI partition after Installation HERE
Step 7 - Starting a real fine tune with full ACPI solution. About Premium and Donators users check HERE
Step 8 - USB Port Mapping HERE
Step 9 - Audio Solution HERE
Step 10 - Dual Boot with OpenCore and Full ACPI Solution HERE
Step 11 - How to update OpenCore bootloader HERE
Step 12 - How to generate SMBIOS and Serial on Hackintosh HERE
Step 13 - Mobile Intel HD Graphics HERE
Step 14 - Run Olarila Repair one time HERE
Step 15 - Olarila Guides and Tutorials HERE. More than a hundred tutorials for your Vanilla.
Credits:
We're all here to have fun and learn from each other! That's all Folks!
8 minutes ago, T19 said:
RunMe dump
any change from new DSDT
the boot is stuck at 1 minute of the progress bar at apple logo at boot
windows boot options don't show?
Edited by T19
no idea
Hi @MaLd0n, After the re-install of big sur on 1 of my m.2 and re-installed Monterey on another m.2. The install went fine and finished and I can boot into Monterey but after a few minutes it completely freezes and I have to restart the PC again. Can the Asus Rocket lake PC run Monterey.
Gigabyte Z490 Vision D
i7-11700K RocketLake
Powercolour RX6800XT
MacOS Big Sur
Monterey
2 hours ago, suren munoo said:
Hi @MaLd0n
u need use debug things for check what cause it
if u have a lan 2.5 for example need disable this device
need wait nexts beta release monterey
On 7/10/2021 at 3:04 AM, Xavier Lim Zheng Yang said:
Hi, Is opencore available for X58 LGA1366?
why not
what
I try to install hackintosah to my pc and I used this EFI
I used the opencore and clover EFI but in both of them I have same error and this error run again and again
please help me
my system :
Laptop Asus vivobook 15
cpu : core i3 1005g1
vga : Intel(R) UHD Graphics
ram : 12GB
Edited by amirber
use usb 2 port
40 minutes ago, amirber said:
I use from usb2 I have 2 ports and I try both of them
use only one topic
thank you Just installed Monterey Beta on my Laptop and it looks stable with my fav Apps, i'm keeping it :)
do you want to take a look to my EFI folder and fine tuning my system please ?
this is RunMe:
Send me MSIs-MacBook-Pro.zip
Hack Pro: Asus Strix Z590i, i9-11900K, RX 6900 XT, 1TB Samsung QVO SSD, RAM 16GB Corsair RGB @3200Mhz (Big Sur) OC
Hackbook Pro: (MSI GE63 Raider RGB) i7-8750H, Intel UHD 630, GTX1070 8GB(disabled), 16GB RAM @2666Mhz (Big Sur) OC
