Hey I really want to install Mac Os on my Pc but unfortunately couldn’t because of hardware limitations. These are my specs.
1. Intel Pentium Gold G6400 10th gen
2. Intel UHD 610 IGPU
3. H410M H Motherboard
Bcos of IGPU, I can’t but if i can add Nvidia Geforce GT 710 or GIGABYTE RADEON RX 560, Can I install Hackintosh then ??
please any help would be appreciated.
610 dont work u need one dgpu
rx560
try with 0x0306A0
Any guide that i can follow because olarila doesn’t have guide particular for pentium users and also Dortania doesn’t have.. if you can point me towards the guide.
On 5/10/2021 at 7:04 PM, MaLd0n said:
Hi, i bought Nvidia GT710 graphics and tried installing catalina with Opencore bootloader.. but kernel panicked when i booted USB and system restarts.. check my efi folder and config.plist and also the opencore error log. Please suggest where m i going wrong ??
[Efi](https://drive.google.com/folderview?id=11svN8S1LnSD1oIpeii_0akksmUk85E72)
EFI CATALINA.zip
Dear Maldon.. I saw your many posts and have seen that you help many out there who are trying to install Hackintosh on their systems. I too tried opencore methods, olarila methods and Niresh hackintosh methods, but i am not not successful.. Can you please care to help me out .. i would really appreciate your help. These are my specs.
Intel Pentium Gold G6400 Coffee lake processor
Zotac Nvidia GT710 DGpu
Acer H410MH Mobo
16GB DDR4 Ram
4HDDs - 1TB, 1TB, 500GB and 120GB
Realtek Ethernet Controller
No wifi and no bluetooth card.
I am adding my Opencore EFI Folder with Config.plist. Please check and help.
Note: I tried spoofing ID in CPUID data and CPUID Mask under Config.plist but system reboots when i try clicking on Install mac OS (External) .
Also attachee is the opencore error log.
u just need a fakecpuid with Olarila folder
Have you seen my config.plist i used fakecpuid by adding in cpuid data and mask in kernel, but still kernel panicked. And which folder are you referring to ??
And for fakecpuid you mean fakeciid.kext ?
Hi Maldon, I downloaded this opencore folder --CHIPSET SERIE 30, 40 (COOFFELAKE / COMETLACOMETLAKE,
Also FakeCPIID.kext Required or not ? And which method should i follow for hackintosh as i have no macos working directly or on virtual machine. But i have downloaded Olarila Big Sur 11.3.1 raw image.
ivybridge Cpuid - 0x0306A0 and SYMBIOS should be iMac 14,2 right ?
this Ivybridge CPUID when entering in Opencore Config.plist should be under Cpuid data and Mask right ??
Kernel - Mask - CPUID1DATA - A0060300 00000000 00000000 00000000
Kernel - Mask - CPUID1MASK - FFFFFFFF 00000000 00000000 00000000
