u need remap HSxx ports first and SSxx ports start appears after that
clean and refresh after reboot?
Yap! Solved it. thanks!
Bcz I edited the wrong plist file on backup disk.
Is it possible to have more then 15 USB ports? one SSXX can't be included.
the correct way is stay with 15 ports
:bye
On my Gigabyte Z490I Aorus Ultra with macOS Monterey 12.3.1, all USB ports are only recognized as USB 2.0. A USB 3.0 and Type-C are not recognized and do not work. What could be the reason?
Check tutorial, clear, refresh, etc
Hi MaLd0n,
While copying form usb3 drive the pen drive gets ejected frquently. The drive is still there but it shows message "the drive not ejected properly". All my usb3 ports shows this same message while copying from it. No problem with usb2 drives. usb3 shows 5Gbps in Hackintool and performs very fast.
Error Message : The operation cannot be completed because an unexpected error occurred(error code : 100006)
I followed your video using Hackintool
Olarila Monterey 12.3.1
i3 10105F, gigabyte h410m, geforce gt 710
I tried the same procedure in another system with gigabyte Z590, but still the same result.
please help
4 hours ago, Sunil K said:
Hi MaLd0n
Use USBInjectAll.kext and XHCI-unsupported.kext and SSDT-UIAC
btw, go to good fine tune and avoid ssdts
I tried mapping, restarting, cleaning , refreshing, USBInjectAll.kext, XHCI-unsupported.kext, SSDT-UIAC . But, I still don't see the SS ports in Hackintool and my usb 3 ports only go up to 480 Mbps. What else can I do or what am I doing wrong? Please help.
Mobo: GIGABYTE H370 AORUS Gaming 3 WIFI
Edited by risk_two
image reupload
start again and follow step by step
On 10/4/2021 at 2:45 AM, MaLd0n said:
try this
use clear and refresh after reboots
I tried this with my new Monterey installation (upgraded from Catalina), putting them both into the kexts/other folder in Clover, booting up using -f arg and doing the kext cache rebuild in terminal and rebooting, and it didn't make any difference. The USBInjectAll kext I had previously was slightly older and I didn't have the XHCI-unsupported kext. I haven't built an SSDT for USB yet. Do I need to install the kexts using OC configurator or some other app? I was able to use nearly all my USB ports for SSDs but only the 3.2 red ports worked for my WD external drives, but after using a WD My Book strangely I can't get the external drives to work with 3.2 anymore, the My Book works on USB 2.0 front i/o only and the MyPassport drives won't work with anyt USB port until I boot up my machine in Mojave using the previous EFI. Very strange!!
Edited by PliSsK
