mengshi Posted May 26, 2021 Posted May 26, 2021 (edited) 1 hour ago, MaLd0n said: u need kill device ehc1 and ehc2 How? by using uia_exclude=PR01;PR12 ? 1 hour ago, mengshi said: How? by using uia_exclude=PR01;PR12 ? Found SSDT-EHCx_off.aml. Ok. Trying this.... Ok. This got rid of the EHC1 and EHC2 but I am still missing 2 USB 3.0 ports. Other than adding SSDT-EHC1_off.aml, the setting is the same as previous just that Hackintool doesn't display the EHCx anymore. Still total 15 ports. Could it be because I'm using Haswell and but running as a Mac Pro 7,1? Needed to do this in order to get my Radeon Graphics card to be in accelerated mode. Interestingly, after this change, booting doesn't cause a sudden spinup of the fans. Those 2 missing USB 3.0 ports are not a problem at the moment. Screenshot 2021-05-26 at 8.44.24 PM.png.zip Screenshot 2021-05-26 at 8.51.06 PM.png.zip Edited May 26, 2021 by mengshi alter
Administrators MaLd0n Posted May 27, 2021 Author Administrators Posted May 27, 2021 Post one Full Dump with Ioreg.https://www.olarila.com/topic/10301-olarila-runme-dumper/https://olarila.com/files/Utils/RunMe.app.ziphttps://olarila.com/files/Utils/IORegistryExplorer.app.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
mengshi Posted May 27, 2021 Posted May 27, 2021 (edited) 1 hour ago, MaLd0n said: Post one Full Dump with Ioreg.https://www.olarila.com/topic/10301-olarila-runme-dumper/https://olarila.com/files/Utils/RunMe.app.ziphttps://olarila.com/files/Utils/IORegistryExplorer.app.zip IOREG dump failed message. Dumping generic IOREG report. The file is bigger than than 2.93MB so cannot attach here. How do you suggest I upload this file? Mine is 4.1MB Edited May 27, 2021 by mengshi
Administrators MaLd0n Posted May 27, 2021 Author Administrators Posted May 27, 2021 google drive or other service -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
mengshi Posted May 27, 2021 Posted May 27, 2021 5 minutes ago, MaLd0n said: google drive or other service https://1drv.ms/u/s!AumDSEaF6xVbmV26tLmndLZ3dSAo?e=djku4A
Administrators MaLd0n Posted May 27, 2021 Author Administrators Posted May 27, 2021 10 minutes ago, mengshi said: https://1drv.ms/u/s!AumDSEaF6xVbmV26tLmndLZ3dSAo?e=djku4A DSDT.aml.zip uncheck xhci port patch, reboot and start remap remove all ssdts use only dsdt enable rebase regions -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
mengshi Posted May 30, 2021 Posted May 30, 2021 Sorry, this one didn't work correctly. I managed to get perfection by doing the following: Researched further and found that for the 9 series of chipset, I needed FakePCIID_XHCIMux.kext and FakePCIID.kext. My process to get perfection (on the Gigabyte H97-HD3 which has 4 physical USB 3.0 and 2 physical USB 2.0 at the rear, 2 USB 3.0 and 2 USB 2.0 at the front (from an onboard header)), Haswell CPU running as Mac Pro 7,1 1. Rename EHC1 to EH01; rename EHC2 to EH02, rename XHCI to XHC; rename XHC1 to XHC. 2. Initially untick XhciPortLimit 3. Remove USBInjectAll.kext . 4. Reboot . 5. Run corpnewt's USBMap script. This time all 6 SS ports show up numbered nicely 1-6, with USB 2.0 detected on EHC. Plug in a USB 3.0 to each port to register. 6. This time USBMap is correct. Just generate the kext and no need editing. 7. Pot the above USBMap.kext in the correct OC folder, re-tick XhciPortLimit and reboot. -------------------------- If I get you to generate a DSDT with the above current working setting, will it make sense? (Just to try to go the DSDT method). Below is the RunMe link generated with the above perfect setup. Thanks https://1drv.ms/u/s!AumDSEaF6xVbmV6gDLkKa7Rs5Q6I?e=Nonh3P
Administrators MaLd0n Posted May 30, 2021 Author Administrators Posted May 30, 2021 9 hours ago, mengshi said: I needed FakePCIID_XHCIMux.kext and FakePCIID.kext. no u don't need need this shit this kext set to usb 2 and not usb 3 device is wrong -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
mengshi Posted May 30, 2021 Posted May 30, 2021 (edited) 2 hours ago, MaLd0n said: no u don't need need this shit this kext set to usb 2 and not usb 3 device is wrong No. It works. As Rehabman described it "The effect is to route any USB2 devices attached to the USB2 pins on the XHC ports to EHC1. In other words, handle USB2 devices with the USB2 drivers instead of the USB3 drivers (AppleUSBEHCI vs. AppleUSBXHCI)." Tested it already. See the screenshot. It is the only way I found that got the 6 USB 3.0 ports under XHC with this series 9 motherboard. Any other methods it displays like the screenshot I showed in previous message. All 6 USB 3.0 work at correct speed. The USB 2.0 ports are under EHC and the only "problem" is that the devices are not shown in Hackintool but are shown in System Report. This method is unnecessary with motherboards newer than series 9 (I think.) Screenshot 2021-05-30 at 11.41.20 PM.png.zip Screenshot 2021-05-30 at 11.44.14 PM.png.zip Edited May 30, 2021 by mengshi
Administrators MaLd0n Posted May 30, 2021 Author Administrators Posted May 30, 2021 is wrong bro is a non-sense way not a good and vanilla solution with my dsdt u see only xhci device serie 8+ we just need xhci -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Administrators MaLd0n Posted June 15, 2021 Author Administrators Posted June 15, 2021 *UPDATE FIRST POST* -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
XLR Posted June 18, 2021 Posted June 18, 2021 When i insert usb2 stick, it appears on the desktop in all ports, but many times it doesn't appears in hackintool, is it normal?
Administrators MaLd0n Posted June 18, 2021 Author Administrators Posted June 18, 2021 5 minutes ago, XLR said: When i insert usb2 stick, it appears on the desktop in all ports, but many times it doesn't appears in hackintool, is it normal? some mobos have internal hub 4 ports work inside this hub in screenshot above for example is common and good for us. we can use more ports in this case 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
redx30 Posted June 24, 2021 Posted June 24, 2021 Hi i remap my usb ports and make all the step of this tutorial but mi usb 3.0 dont work with my mouse or keyboard or usb bluetooh only work with memory usb so i need remove the usbinjected.kext to work normally and i have a PCi-e USB card to extra port but i can use the sytem recognizes but dont work anythinyn port i dont find any solve to use my extra port on my PCI-e card usb the pci-e card is uPD720200 nec corporation
Administrators MaLd0n Posted June 24, 2021 Author Administrators Posted June 24, 2021 8 hours ago, redx30 said: Hi start again all ports need work if ur remap is correct -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
redx30 Posted June 24, 2021 Posted June 24, 2021 5 hours ago, MaLd0n said: start again all ports need work if ur remap is correct hi, i make this tutorial 5 times and my USB only work with memory usb devices not with peripherals like mouse microphone or keyboard when i use the USBijectec.kext that kext never work in my hackintosh but the most importan, is need working my PCI-E card USB any solves to make work that ?
Administrators MaLd0n Posted June 24, 2021 Author Administrators Posted June 24, 2021 2 hours ago, redx30 said: is need working my PCI-E card USB any solves to make work that ? this tutorial is fot built ins usb ports not pci cards pci cards need a native support -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
redx30 Posted June 25, 2021 Posted June 25, 2021 4 hours ago, MaLd0n said: this tutorial is fot built ins usb ports not pci cards pci cards need a native support who pci-e card you recommend ?
Administrators MaLd0n Posted June 25, 2021 Author Administrators Posted June 25, 2021 14 hours ago, redx30 said: who pci-e card you recommend ? have many check ebay or amazon -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
andytang Posted August 13, 2021 Posted August 13, 2021 Hi everyone, I have remap my all my usb port. Final, I have 14 highlight green port on hackintool. the only problem is that I have usb 3.1 type A and usb 3.1 type C on my Asus Z170-AR. when I plug my usb 3.1 in both port type A and C, my system detected device and I can use it on both 3.1 usb ports. But on hackintool doesn’t detect device. I want to know how can I re map the usb 3.1 type A and type C on hackintool. Thank you very much
