Criei o pendrive bootavel com a imagem do Mojave que o site disponibiliza... Tudo ok
mais na hora de instalar no notebook não aparece a opção de instalar
como resolvo isto ?
como resolvo isto ?
You have Select the usb stick  from the bios? and it does not start?
5 minutes ago, anto barreca said:
Clover é iniciado, você configurou a bios, certo? Não mostre o instalador
https://dortania.github.io/OpenCore-Install-Guide/config-laptop.plist/kaby-lake.html#cleaning-up
I am new in the middle of hackintosh and I want to install it on my notebook .. I am struggling for hours to solve this problem I do not understand much ... so my difficulty
I really want to learn how to properly install my notebook is a samsung expert x23 model 2017 (np300e5m-xd1br)
Processor: i5 7200U
memory: 8gb
hd: 1tb
Graphics: gt 920mx
Edited by Yago Farias
Processor: i5 7200U
memory: 8gb
hd: 1tb
Graphics: gt 920mx
However, it is important that you have set the bios correctly
sorry which image did you download?
you need to disable this
Disable
  • Fast Boot
  • Secure Boot
  • Serial/COM Port
  • Parallel Port
  • VT-d (can be enabled if you set DisableIoMapper to YES)
  • CSM
  • Thunderbolt(For initial install, as Thunderbolt can cause issues if not setup correctly)
  • Intel SGX
  • Intel Platform Trust
  • CFG Lock (MSR 0xE2 write protection)(This must be off, if you can't find the option then enable AppleXcpmCfgLock under Kernel -> Quirks. Your hack will not boot with CFG-Lock enabled)
Disable
  • Fast Boot
  • Secure Boot
  • Serial/COM Port
  • Parallel Port
  • CSM
  • Intel SGX
i'm not sure if it's compatible but i would disable your gtx,
Just now, Yago Farias said:
Disable this in the bios of the pc itself or in the boot of the clover?
in the bios
and these are the ones you need to enable
Enable
  • VT-x
  • Above 4G decoding
  • Hyper-Threading
  • Execute Disable Bit
  • EHCI/XHCI Hand-off
  • OS type: Windows 8.1/10 UEFI Mode
  • DVMT Pre-Allocated(iGPU Memory): 64MB
  • SATA Mode: AHCI
in the bios
I disabled what I could disable, but it still didn't work
5 buttons appear with the windows flag
1 - boot mircrosoft EFI boot from EFI
2 - boot from
3 - boot from EFI
4 - boot from legacy HD3
5 - boot from legacy HD4
2 - boot from
3 - boot from EFI
https://prntscr.com/120skju
2 - boot from
3 - boot from EFI
thi is clover boot menu you need operating in the bios of pc
chance sata to haci mode ,csm disable ,os type uefi mode, DVMT 64MB ,fastboot disable,secure boot disable ,serial / parallel port disable
6 minutes ago, anto barreca said:
esta ?
  • Tipo de sistema operacional: Windows 8.1 / 10 Modo UEFI
  • DVMT pré-alocado (memória iGPU): 64 MB
  • Modo SATA: AHCI
  • Transferência EHCI / XHCI
this does not have in the laptop bios
I did not understand
this guy has an earlier version of mine
@Anto Barreca
@Anto Barreca
as I thought it is not compatible .. it must be disabled from the bios ,take a look here
https://downloadcenter.samsung.com/content/UM/201702/20170217144647887/Win10_Manual_ENG.pdf
 they are these option
Turn on the computer. 2 Before the Samsung logo appears, press the F2 key several times. 3 Select the Boot menu. 4 Set Fast BIOS Mode to Off. 5 Set Secure Boot Control to Off. 6 Set OS Mode Selection to uefi mode and then restart the computer.
Edited by anto barreca
