dimitris12 Posted April 22, 2021 Posted April 22, 2021 Can someone help me to patch my audio (alc256) ? Right now I'm using layout id 21. Every audio source is working ok , except 2problems : 1) line in source doesn't work 2) biggest problem is that sometimes (when audio is idle) starts a very annoying high pitch noise from speakers and cpu spikes at max. Attaching my codec_dump from linux. Thanks in advance. codec_dump linux.txt.zip
Administrators MaLd0n Posted April 22, 2021 Administrators Posted April 22, 2021 https://www.olarila.com/topic/6074-guide-easy-audio-solution-with-applealc-clover-and-opencore/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
anto barreca Posted April 22, 2021 Posted April 22, 2021 1 hour ago, dimitris12 said: Can someone help me to patch my audio (alc256) ? Right now I'm using layout id 21. Every audio source is working ok , except 2problems : 1) line in source doesn't work 2) biggest problem is that sometimes (when audio is idle) starts a very annoying high pitch noise from speakers and cpu spikes at max. Attaching my codec_dump from linux. Thanks in advance. codec_dump linux.txt.zip 2.06 kB · 1 download Realtek ALC256/ALC 3246. 0x100002, layout 5, 11, 13, 14, 16, 17, 19, 21, 22, 23, 28, 56, 57, 66, 67, 69, 76, 77, 88, 97
