jnokia Posted May 11, 2022 Posted May 11, 2022 (edited) Hi Daniel, I had successful with Mac OS Catalina 10.15.7, GA590 UD AC, Intel Core i7 11700K, Geforce 9600 GT. For Gforce 9600 GT I used Legacy Video Patch. I don't get to boot in safe mode, can you help-me? My send me file is here: https://drive.google.com/file/d/1HYBIu6YFaLxfmbkAVyAhd8ayyZBe40AO/view?usp=sharing Thank you. Edited May 11, 2022 by jnokia
Administrators MaLd0n Posted May 11, 2022 Author Administrators Posted May 11, 2022 2 hours ago, jnokia said: Geforce 9600 GT. For Gforce 9600 GT I used Legacy Video Patch. forget it u need one amd card ike rx560 for hardware accel(hevc/h264) -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
jnokia Posted May 11, 2022 Posted May 11, 2022 I solve this problem today, but my Gforce 9600 GT was fully working, now I put a Gforce 650 Ti is better and working fully, in the future I buy a amd graphics. For solve this problem I reinstalled the Catalina OS with other installer, because I was having crash in microsoft office and i didn't get to put the extensions of Safari, thank you for your attention.
jm26200 Posted October 11, 2022 Posted October 11, 2022 (edited) error sorry Edited October 12, 2022 by jm26200 error Mac mini macOS Monterey 12.7.5 (21H1211) Carte mère : GA-Z590 UD AC, CPU : Intel BOX I5-11400 LGA : 1200, RAM 32 Go DDR4, Intel Rocket Lake-S GT1 - Graphiques AMD Radeon RX 6600 8 Go - OS: macOS Sonoma 14.5 [Open Core 1.0.0 ] (23F5059e) & Windows 11 Professionnel Insider Preview (canal Canary) 24H2 26200.5001
akshar3375 Posted February 7, 2023 Posted February 7, 2023 Hey Maldon please check my build generated from runme app thanks a lot My send me file is here: https://drive.google.com/file/d/1rHM7w_T8eVnh1p-aB13ChFi_dypWOQzF/view?usp=share_link
exxot Posted April 3, 2023 Posted April 3, 2023 Hey Maldon, I have followed this guide and managed to instal OC Catalina, which I upgraded to Ventura. Everything seems OK,only my old SATAdrives are not recognised - even I can see them in bios and OC screen. Any ideas?
Administrators MaLd0n Posted April 3, 2023 Author Administrators Posted April 3, 2023 9 hours ago, exxot said: Hey Maldon Hey Post one Full Dumphttps://olarila.com/files/Utils/RunMe.app.zip and one Ioreghttps://olarila.com/files/Utils/IORegistryExplorer.app.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
exxot Posted April 4, 2023 Posted April 4, 2023 On 4/3/2023 at 1:48 PM, MaLd0n said: Hey Post one Full Dumphttps://olarila.com/files/Utils/RunMe.app.zip and one Ioreghttps://olarila.com/files/Utils/IORegistryExplorer.app.zip Hey MaLd0n here they are: Franz’s iMac Pro.ioreg.zip Send me Franzs-iMac-Pro.zip
Administrators MaLd0n Posted April 4, 2023 Author Administrators Posted April 4, 2023 Use this efi folder https://www.transfernow.net/dl/2023040446uB51Qw -Bios/UEFI in full default settings(Just change settings if need) -Delete old EFI folder and paste new. Don't use merge files -Don't use Drag and Drop into EFI partition. Use Copy/Paste instead -Reset NVRAM one time - with OpenCore use entry "Reset Nvram" / with Clover use F11 key on boot screen Need remap USB https://www.olarila.com/topic/14220-hackintosh-usb-port-mapping-guide-2023/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
UBond Posted July 12, 2024 Posted July 12, 2024 Hi Maldon, Thanks you for the guides. I have got Z590 UD (non-WiFi) mobo with i5-11400F and Sapphire RX460 running Ventura. Sleep isn't working. Here is my dump. Please help. https://drive.google.com/file/d/1dnM7MoeEtgUOgOOooHWDB_LDevRn8SjR/view?usp=sharing
Administrators MaLd0n Posted July 12, 2024 Author Administrators Posted July 12, 2024 7 hours ago, UBond said: Sleep isn't working. Here is my dump. Please help. Check if wake work with this patch via power button Quote <dict> <key>Base</key> <string></string> <key>BaseSkip</key> <integer>0</integer> <key>Comment</key> <string>_PRW to XPRW</string> <key>Count</key> <integer>0</integer> <key>Enabled</key> <true/> <key>Find</key> <data>X1BSVw==</data> <key>Limit</key> <integer>0</integer> <key>Mask</key> <data></data> <key>OemTableId</key> <data></data> <key>Replace</key> <data>WFBSVw==</data> <key>ReplaceMask</key> <data></data> <key>Skip</key> <integer>0</integer> <key>TableLength</key> <integer>0</integer> <key>TableSignature</key> <data></data> </dict> -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
UBond Posted July 13, 2024 Posted July 13, 2024 On 7/12/2024 at 9:44 PM, MaLd0n said: Check if wake work with this patch via power button It works. Thanks. Is waking via power button the only option? Not possible to wake using keyboard or mouse?
Administrators MaLd0n Posted July 13, 2024 Author Administrators Posted July 13, 2024 U need check what device cause auto-wake and kill it -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
UBond Posted July 14, 2024 Posted July 14, 2024 18 hours ago, MaLd0n said: U need check what device cause auto-wake and kill it When I disconnected the USB port of my Fenvi HB1200, sleep work. Looks like it is to do with the bluetooth of the Fenvi. I need to use the bluetooth for my keyboard and mouse though. Any possible solution? In addition, while doing the tests on the USB ports, my machine all of sudden develop this issue that when I plugged in an USB 3.0 thumb drive, it doesn't show up in Finder and it shows up as 'composite device' in SI. The funny thing is that if I leave the thumb drive in the port during boot up, it shows up in the Finder okay! If I eject it and put in back, then it is not recognised like before. Pretty sure it was working after I did the USB port mapping with Hackintool.
Administrators MaLd0n Posted July 14, 2024 Author Administrators Posted July 14, 2024 Do u tried change USB mobo header? -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
UBond Posted July 17, 2024 Posted July 17, 2024 On 7/15/2024 at 1:48 AM, MaLd0n said: Do u tried change USB mobo header? For the USB, I changed to another thumb drive and it is okay. It turns out the thumb drive I have been used for testing suddenly developed issues with Ventura. It still works on Windows and MacOS High Sierra but It doesn't work on Ventura and Sonoma, even on real MacBook! No idea why. For the sleep issue, GA Z590 UD uses USB 2.0 Hubs for all the 2.0 ports and someone mentioned that causes sleep issues. As suggested, I wired the Bluetooth USB connector to a 3.0 port. The bluetooth works and machine properly goes to sleep and wake up through a wired USB mouse/keyboard. However, I can't wake it up with my bluetooth keyboard. Any idea why?
