I would like to use 5,1 System Definitions. Please Note: I am using core i5-2400 processor and GTX 560 GPU. I found one of the tutorial it says: If you insist on installing either of these two 4,1/5,1 system definitions, be sure to remove AppleTyMCEDriver.kext and AppleGraphicsPowerManagement.kext from /System/Library/Extensions.
Should i delete those two kext and make new system definitions? Or i can simply use 5,1 System Definitions.
As i know AppleGraphicsPowerManagement.kext needs for GPU full acceleration.
Looking for the suggestion. Thanks in advance.
If you are talking about MacPro4,1/5,1 SMBIOS, none of them is recommended for your CPU (LGA1155) http://Olarila.com/forum/viewtopic.php?f=2&t=1302
Which system Definition should i use
- iMac 12,1 or 12,2
- MacBook Pro 8,1 or 8,2 or 8,3
Please define by yourself for me :)
I swear i found the quickest and appropriate answer from this forum and obviously all from you.
Thanks You Bro. Thanks from Bottom of My Heart.
