NoturnoJpop Posted March 14, 2021 Posted March 14, 2021 Hello, good afternoon, how are you? I have a R7 3800x, GTX 1080TI and Asus Prime Pro X470 motherboard. I'm trying to install Big Sur and even I can, but when you restart the boot it won't go, it keeps looping and doesn't load the system. Can someone help me please? Thanks 04:256 00:034 AAPL: #[EB.OPT.LXF|F] <"\\System\\Library\\CoreServices\\PlatformSupport.plist"> 04:290 00:034 AAPL: #[EB.LD.LF|IN] 0 1 <"\\System\\Library\\CoreServices\\PlatformSupport.plist"> <"0"> 04:326 00:035 AAPL: #[EB|B:VAw] 04:362 00:035 AAPL: #[EB|P:CPR] N 04:397 00:035 AAPL: #[EB|P:MPI] N 04:432 00:035 AAPL: #[EB|P:BPI] N 04:467 00:034 AAPL: #[EB|KMR] 306659328 04:800 00:332 AAPL: #[EB.CS.CSKSD|+] 04:835 00:035 AAPL: #[EB.CS.CSKSD|!] Err(0xE) <- RT.GV boot-info-payload 8D63D4FE-BD3C-4AAD-881D-86FD974BC1DF 05:172 00:337 AAPL: #[EB.G.CS|-?] Ok(0) 05:207 00:035 AAPL: #[EB.LD.LF|IN] 0 1 <"<null string>"> <"1"> 05:269 00:061 AAPL: #[EB.B.SBS|SZ] 739896 05:308 00:039 AAPL: #[EB|B:SHA] <6c4c18c09ba51a04539131ed525a219a7a175c00> 05:344 00:035 AAPL: #[EB.WL.PWLFNV|!] Err(0xE) <- RT.GV wake-failure 7C436110-AB2A-4BBB-A880-FE41995C9F82 05:379 00:034 AAPL: #[EB.WL.DT|!] Err(0xE) <- EB.WL.PWLFNV 05:413 00:034 AAPL: #[EB.WL.PWLFRTC|NONE] 05:448 00:034 AAPL: #[EB.WL.DT|!] Err(0xE) <- EB.WL.PWLFRTC 05:483 00:035 AAPL: #[EB.LD.LKC|D] <"System\Library\KernelCollections\BootKernelExtensions.kc.development"> 05:520 00:036 AAPL: #[EB.LD.LF|IN] 0 1 <"System\\Library\\KernelCollections\\BootKernelExtensions.kc.development"> <"0"> 05:857 00:336 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"System\\Library\\KernelCollections\\BootKernelExtensions.kc.development"> 05:892 00:034 AAPL: #[EB.LD.LKC|R.2] <"System\Library\KernelCollections\BootKernelExtensions.kc"> 05:927 00:035 AAPL: #[EB.LD.LF|IN] 0 1 <"System\\Library\\KernelCollections\\BootKernelExtensions.kc"> <"0"> 12:171 06:244 AAPL: #[EB|SB:P] 0x1 12:444 00:272 AAPL: #[EB|SB:SBGMFNS] j137ap.im4m 12:485 00:040 AAPL: #[EB|SB:MF] System\\Library\\KernelCollections\\BootKernelExtensions.kc.j137ap.im4m 12:520 00:034 AAPL: #[EB.LD.LF|IN] 0 1 <"System\\Library\\KernelCollections\\BootKernelExtensions.kc.j137ap.im4m"> <"0"> 13:138 00:618 AAPL: #[EB|SB:MKRN] 13:527 00:389 AAPL: #[EB.LD.LKFS|-?] Ok(0) 13:568 00:040 AAPL: #[EB.LD.LKC|-?] Ok(0) 13:604 00:036 AAPL: #[EB|FWFM] 0x00000000FF9FFF3F 13:639 00:034 AAPL: #[EB|FWFT] 0x00000000FD8FF53E 13:674 00:035 AAPL: #[EB|BST:REV1] 13:708 00:034 AAPL: #[EB|CSR:OUT] 0x00000067 13:744 00:035 AAPL: #[EB.BST.FBS|+] 13:780 00:035 AAPL: #[EB|GIP:PHS.1] Boot 1 13:815 00:035 AAPL: #[EB|GIP:PCT] 0x2 14:151 00:336 AAPL: #[EB|GIP:PHS.2] Boot 1 14:185 00:033 AAPL: #[EB.BST.FBS|ADSZ] 0 14:514 00:329 AAPL: #[EB.BST.FBS|KSSZ] 0 14:549 00:034 AAPL: #[EB|SB:SBGMFNS] j137ap.im4m 14:583 00:034 AAPL: #[EB|RH:PF] usr\standalone\OS.dmg.root_hash 14:618 00:034 AAPL: #[EB|RH:MF] <"usr\\standalone\\OS.dmg.root_hash.j137ap.im4m"> 14:652 00:034 AAPL: #[EB.LD.LF|IN] 0 1 <"usr\\standalone\\OS.dmg.root_hash"> <"0"> 14:687 00:034 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"usr\\standalone\\OS.dmg.root_hash"> 14:721 00:034 AAPL: #[EB.RH.LRH|P!] Err(0xE) <- EB.LD.LF 14:756 00:034 AAPL: #[EB.BST.FBS|!] Err(0xE) <- EB.RH.LRH 15:093 00:337 AAPL: #[EB.B.WFDW|!WF] Err(0xE) 0 15:128 00:034 AAPL: #[EB|LOG:DT] 2021-03-14T14:23:32 15:163 00:034 AAPL: #[EB|LOG:EXITBS:START] 2021-03-14T14:23:32
Administrators MaLd0n Posted March 14, 2021 Administrators Posted March 14, 2021 change ur gpu and go to bigsur with this folder https://tinyurl.com/y6g7mn3b -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
NoturnoJpop Posted March 15, 2021 Author Posted March 15, 2021 14 hours ago, MaLd0n said: mude sua GPU e vá para bigsur com esta pasta https://tinyurl.com/y6g7mn3b Is there no stable kext for GTX 1080 TI?
Administrators MaLd0n Posted March 15, 2021 Administrators Posted March 15, 2021 high sierra use folder above -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
NoturnoJpop Posted March 15, 2021 Author Posted March 15, 2021 I was able to install thanks, now which clover can I use to boot from HD directly? Can the high sierra kext work? Thanks
anto barreca Posted March 15, 2021 Posted March 15, 2021 you have to use the same efi inside the usb you used to install, and copy it to the efi partition of the disk
NoturnoJpop Posted March 15, 2021 Author Posted March 15, 2021 2 hours ago, anto barreca said: you have to use the same efi inside the usb you used to install, and copy it to the efi partition of the disk Which program do I use to find the partition to replace EFI?
anto barreca Posted March 15, 2021 Posted March 15, 2021 Just now, NoturnoJpop said: Which program do I use to find the partition to replace EFI? https://www.olarila.com/files/Utils/ESP Mounter Pro.app_v1.9.1.zip 1
Administrators MaLd0n Posted March 15, 2021 Administrators Posted March 15, 2021 https://olarila.com/files/Utils/ESP Mounter Pro.app_v1.9.1.zip 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
NoturnoJpop Posted March 15, 2021 Author Posted March 15, 2021 I am not finding the EFI partition of the HD even mounting all the parts of the HD I only find the EFI of the USB that I had already separated.
Administrators MaLd0n Posted March 15, 2021 Administrators Posted March 15, 2021 if u format in GUID, EFI partition is generated -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
NoturnoJpop Posted March 16, 2021 Author Posted March 16, 2021 So, could it be the type of HD formatting I used was it? Because I built all the HD partitions but none of them are or have EFI.
Administrators MaLd0n Posted March 16, 2021 Administrators Posted March 16, 2021 -OpenCore Vanilla Guidehttps://www.olarila.com/topic/8918-opencore-vanilla-guide-step-by-step-full-dsdt-patched-or-ssdt/ -Clover Vanilla Guidehttps://www.olarila.com/topic/5794-hackintosh-guide-install-macos-with-vanilla-olarila-image-step-by-step-install-and-post-install-windows-linux-or-mac/ -Premium Usershttps://www.olarila.com/topic/7717-important-premium-and-donators-users/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
