Im not able to install chameleon using the chameleon wizard, the drop down for target partition is blank. I also tried to use the option to install from 1386 folder and it didnt install.
Was wondering if i could just install the below 3 kexts for video :-
ATIxxxxController.kext
ATISupport.kext
AMDRadeonAccelerator.kext
Do i need ATIFramebuffer.kext?
Why it didn't install? Any error messages? You can use an installer pkg http://Olarila.com/forum/viewtopic.php?f=9&t=70
I don't know about the video, I use nVidia. Look here http://Olarila.com/forum/viewtopic.php?f=18&t=736
Yippie! Got Audio working by removing the Nodes to patch entry :D
Now, Video is remaining.
As i didnt get a confirmation earlier, i wanna know if i need Chameleon for video to work?
Im getting options now to install chameleon, once i moved those files from my windows ntfs drives to the mac drive. Its able to detect the target partition now. So i can install it.
But just to let you know, I've already installed all the video kexts:-
ATI6000Controller.kext -- Got a HD6950
ATISupport.kext
ATIFramebuffer.kext
But it gets stuck on the following screen when i boot without graphicsenabler=no
Did you read that topic about ATI?
I understand that after tweaking the kexts you need GraphicsEnabler=yes and maybe AtiConfig=[framebuffer name].
Those are Chameleon features, so yes, you need Chameleon, unless you use an enabler kext or other boot loader with graphics enabler feature.
So you're saying if i boot from USB using "GraphicsEnabler=Yes AtiConfig=Cayman" my video should work fine?
I've edited the ATI6000Controller.kext and the AMDRadeonAccelerator.kext to support my Video card.
Ive not installed ATIRadeonx3000 as the video thread says to use AMDRadeonAccelerator.kext for 10.8.
Did you get anything of the image above?
The idea is install Chameleon to HD and configure those options in the config file, but you can type them at boot using USB.
Which option from the top of Chameleon wizard do i use?
Folder on disk, Buildbot, Drop Box or Built in?
Ok so i tried to boot with "GraphicsEnabler=Yes AtiConfig=Gubba". I got stuck on the screenshot above. Any ideas?
