devilindisguise Posted July 28, 2012 Posted July 28, 2012 Hi there, I've managed to install ML on my PC a day using the bootable USB method. Im on the desktop and im able to play around with the OS, but i have no audio, video or Ethernet. Is this because im still booting to the desktop using GraphicsEnabler=No -f ? Im aware the video kexts are not installed as i had to remove them from the USB to install ML. If i do fix the video issue would i be able to boot to the OS without using GraphicsEnabler=No -f ? which in turn will give me my audio and ethernet back? Ive not installed the Chameleon Bootloader, not sure if i need to and how. In short, Ive basically just installed the OS by removing the video kexts and i get to the desktop using "GraphicsEnabler=No -F". Im not sure where to go from here and how. Help would be most appreciated. Thanks.
artur-pt Posted July 29, 2012 Posted July 29, 2012 hello we are not magician read u post, write and write and say nothing no reference at all u hardware.. help that way not easy good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
devilindisguise Posted July 29, 2012 Author Posted July 29, 2012 You really have a hard time reading and comprehending english dont you? Every line in my post has some details mentioned. If you need hardware details you can just ask. im not here to get myself spoken rudely to by you or anyone. so watch your manners. i can take my queries to another forum. If you just answer those questions as is i believe that would sort my issue. My issue is not hardware specific, but a user who doesnt know where to go next from here and how. Hardware details:- Core i5 750 Asus P5755D mobo ATI HD 6950 2 GB Gkillset 2x2 GB ram. 1 TB seagate HDD & 1 160 GB Seagate HDD. Mac is installed on the 160 GB drive. Any other info u require?
artur-pt Posted July 29, 2012 Posted July 29, 2012 hello if u have mac os x already installed make u /Extra folder with smbios.plist org.chameleon.boot.plist dsdt if u have install chameleon boot loader and search for kext for lan ( search by dev id : vendor id ) sound use kext wizard to install kext system info (to see dev id : vendor id) all that info is in the forum good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
devilindisguise Posted July 29, 2012 Author Posted July 29, 2012 Where do I make this extra folder and where do I get the plist from? Also what do they do? What is dsdt? Why is chameleon required?
Cassio Posted July 29, 2012 Posted July 29, 2012 Try reading this, it's in portuguese but you should understand if you use Google Chrome to translate http://Olarila.com/forum/viewtopic.php?f=2&t=1404 Video http://Olarila.com/forum/viewtopic.php?f=18&t=736 Audio http://Olarila.com/forum/viewtopic.php?f=18&t=454 LAN read first link above to find out, I guess it's this http://lnx2mac.blogspot.com.br/p/realtekrtl81xx-osx-driver.html Where do I make this extra folder and where do I get the plist from? Also what do they do? What is dsdt? Why is chameleon required? Read install guide and topics in DSDT forum. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
hamoodaslam Posted July 29, 2012 Posted July 29, 2012 I am sorry to barge in on this thread but my problem relates to it and here goes - Hello Everyone, I am currently trying to get the nVidia GTS 350M video card going in my ML installation. Even as I was starting with the installation the card was a hit or miss, but if I rebooted enough times it would boot into the graphics screen (Installer/Login). My current setup is ML on a Toshiba A665 laptop with a nvidia Geforce 350M card. So far I have tried and failed with GraphicsEnabler=Y, NVEnabler64, and a rather poor attempt at working out a EFI string (did not even get close to DSDT solution, way to many errors). Your help, anyones help in the matter would be greatly appreciated. Pleeeeaaassseee I am really way over my league with this one, so help a brother out. I was not sure as to what additional information you may require so please ask and I will have it posted, I would welcome if some one wants to remote on to my computer if that helps. My DEV ID for the card 0x0cb0 Vendor ID 0x10de Also while booting I do see a line that reads - AGPM Controller Unknown I currently have a fairly stable Lion 10.7.4 install running. Also if I delete the NVdan50HAL & NVDResman Kext, I am able to boot into ML but with low resolution - 1024x 768. Thank You PS -Hello again - I am attaching my ioreg output from a running Lion install if it helps. I am running chameleon for my boot loader. Thank You again ioreg.txt.zip
devilindisguise Posted July 29, 2012 Author Posted July 29, 2012 Thanks Cassio, the first link really helps. I also wanted to know if i install Chameleon (the boot loader) , will it detect my Windows 7 install on the other HDD and give me an option to boot into it? or will i have to edit it? Also once i install Chameleon will i be able to boot to MAC with using GraphicsEnabler=No -f ?
Cassio Posted July 29, 2012 Posted July 29, 2012 You'll probably need tweaks in video kexts to be able to boot with GraphicsEnabler=yes, see the link about ATI graphics. About Windows, I believe the best option is installing Chameleon with the boot0md option (use Chameleon Wizard) and set the Windows HD as first in boot order (BIOS). -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
devilindisguise Posted July 31, 2012 Author Posted July 31, 2012 When installing Chameleon, do i just select boot0md option and install? Or do i need to configure anything else on there?
Cassio Posted July 31, 2012 Posted July 31, 2012 Select boot0md, select target partition (OS X) and install. It will ask where to install boot0md, then choose Windows HD. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Cassio Posted July 31, 2012 Posted July 31, 2012 Yes, you can (then use boothfs instead of boot0md), but you may have problems in Windows if it's not in the first HD (BIOS boot sequence). -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
devilindisguise Posted August 1, 2012 Author Posted August 1, 2012 Ive successfully installed the Ethernet driver and it works fine. Audio - Ive installed the kext with editing the primary class to match my dev and vendor id. Now when i play a song, it plays, but i hear no sound. plus i cant move the volume bar. ive seen the fix for this and ive yet to apply it. Im not able to install chameleon using the chameleon wizard, the drop down for target partition is blank. I also tried to use the option to install from 1386 folder and it didnt install. Was wondering if i could just install the below 3 kexts for video :- ATIxxxxController.kext ATISupport.kext AMDRadeonAccelerator.kext Not able to find AMDRadeonAccelerator.kext for download though. also i noticed this was not provided in the usb. Edit -- Will this one work on the HD6950 ? http://www.osx86.net/view/2999-amdradeonaccelerator.kext.html the download says its for the 5xxx series. would i be able to change the info.plist and update it for my 6 series? are there any other kexts needed? Do i need ATIFramebuffer.kext?
devilindisguise Posted August 1, 2012 Author Posted August 1, 2012 Ok this is starting to irritate me now, I installed VoodooHDA.kext initially without editing the dev and vendor ID and when playing a file in itunes, the progress bar while playing a song wouldnt move, it would stay at 0:00:00 and i had no output and input devices in sound preferences. After editing the dev and vendor ID in the kext and reinstalling the kext, i had output and input devices in sound preferences and while playing a song in itunes the progress bar was moving as well like it was playing the song but i couldnt move the volume bar in sound preferences. now when making changes to allow the moving of the volume bar, i again have no output and input devices in sound preferences and the progress bar doesnt move when playing a song.
Cassio Posted August 1, 2012 Posted August 1, 2012 About video, I guess you can restore all kexts from backup after doing required configurations (if your card is compatible). Post your changes in VoodooHDA Info.plist -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
devilindisguise Posted August 1, 2012 Author Posted August 1, 2012 "About video, I guess you can restore all kexts from backup after doing required configurations (if your card is compatible)." dont know what you mean by that. what do i do about chameleon? VoodooHDA Info.Plist <?xml version="1.0" encoding="UTF-8"?> CFBundleDevelopmentRegion English CFBundleExecutable VoodooHDA CFBundleIdentifier org.voodoo.driver.VoodooHDA CFBundleInfoDictionaryVersion 6.0 CFBundleName VoodooHDA CFBundlePackageType KEXT CFBundleShortVersionString 2.7.4 CFBundleSignature ???? CFBundleVersion 2.7.4 IOKitPersonalities VoodooHDA CFBundleIdentifier org.voodoo.driver.VoodooHDA IOClass VoodooHDADevice IOMatchCategory VoodooHDADevice <key>IOPCIPrimaryMatch 0x3b568086 IOProviderClass IOPCIDevice IOUserClientClass VoodooHDAUserClient InhibitCache MixerValues PCM 90 Rec 70 iGain 90 iMix 0 NodesToPatch Codec 0 Node 11 Enable 0 Noise 0 Vectorize VoodooHDAEnableHalfMicVolumeFix VoodooHDAEnableHalfVolumeFix VoodooHDAEnableMuteFix VoodooHDAEnableVolumeChangeFix VoodooHDAVerboseLevel 0 OSBundleLibraries com.apple.iokit.IOAudioFamily 1.1fc9 com.apple.iokit.IOPCIFamily 2.1 com.apple.kpi.iokit 9.0.0 com.apple.kpi.libkern 9.0.0 com.apple.kpi.mach 9.0.0 com.apple.kpi.unsupported 9.0.0
Cassio Posted August 1, 2012 Posted August 1, 2012 If you disable VoodooHDAEnableVolumeChangeFix sound works again? -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
devilindisguise Posted August 1, 2012 Author Posted August 1, 2012 will try that. but earlier when it was disabled, i still couldnt hear sound, but i could see output and input device once i added my dev and vendor id to it and itunes would play the song and the progress bar would move. what do i do about chameleon?
Cassio Posted August 1, 2012 Posted August 1, 2012 Try changing iGain and iMix values in prefPane, once you find good values, config in MixerValues in Info.plist or use the app to restore values on startup http://Olarila.com/forum/viewtopic.php?f=18&t=454 If nothing changes try removing that NodesToPatch entry. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
devilindisguise Posted August 1, 2012 Author Posted August 1, 2012 Im not able to install chameleon using the chameleon wizard, the drop down for target partition is blank. I also tried to use the option to install from 1386 folder and it didnt install. Was wondering if i could just install the below 3 kexts for video :- ATIxxxxController.kext ATISupport.kext AMDRadeonAccelerator.kext Do i need ATIFramebuffer.kext?
Cassio Posted August 1, 2012 Posted August 1, 2012 Why it didn't install? Any error messages? You can use an installer pkg http://Olarila.com/forum/viewtopic.php?f=9&t=70 I don't know about the video, I use nVidia. Look here http://Olarila.com/forum/viewtopic.php?f=18&t=736 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
devilindisguise Posted August 1, 2012 Author Posted August 1, 2012 Yippie! Got Audio working by removing the Nodes to patch entry Now, Video is remaining. As i didnt get a confirmation earlier, i wanna know if i need Chameleon for video to work? Im getting options now to install chameleon, once i moved those files from my windows ntfs drives to the mac drive. Its able to detect the target partition now. So i can install it. But just to let you know, I've already installed all the video kexts:- ATI6000Controller.kext -- Got a HD6950 ATISupport.kext AMDRadeonAccelerator.kext ATIFramebuffer.kext But it gets stuck on the following screen when i boot without graphicsenabler=no
Cassio Posted August 1, 2012 Posted August 1, 2012 Did you read that topic about ATI? I understand that after tweaking the kexts you need GraphicsEnabler=yes and maybe AtiConfig=[framebuffer name]. Those are Chameleon features, so yes, you need Chameleon, unless you use an enabler kext or other boot loader with graphics enabler feature. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
devilindisguise Posted August 1, 2012 Author Posted August 1, 2012 So you're saying if i boot from USB using "GraphicsEnabler=Yes AtiConfig=Cayman" my video should work fine? I've edited the ATI6000Controller.kext and the AMDRadeonAccelerator.kext to support my Video card. Ive not installed ATIRadeonx3000 as the video thread says to use AMDRadeonAccelerator.kext for 10.8. Did you get anything of the image above?
