goksi75 Posted July 21, 2012 Posted July 21, 2012 my PC configuration on which I plan installing Mac OS Lion... MB Gigabyte GA-Z68XP-UD4 with F6 BIOS INTEL i7-3770 3.4GHz 8MB RAM KINGSTON 16GB (4x4GB) 1600MHz DDR3 HyperX T1 VGA ATI Radeon HD 5450 HD SAMSUNG SpinPoint F3 1TB 7k 32MB SATA300 HD103SJ ...I have large problems because I begin installation from boot USB, the computer starts the installation and after about 15 seconds restarts... I don't know what to do in this case, I'm desperate.. I have bad thoughts about this (hehe). Please explain to me the process of making boot USB with Lion, which is connected to my PC config... I would be very grateful if you would help me...
Cassio Posted July 21, 2012 Posted July 21, 2012 How to make boot USB http://Olarila.com/forum/viewtopic.php?f=17&t=134 Check you BIOS settings, enable ACPI 2.0, NX bit (execute disable bit), HPET (64 bit). -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Cassio Posted July 25, 2012 Posted July 25, 2012 Is SATA configured as AHCI in BIOS? -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
goksi75 Posted July 25, 2012 Author Posted July 25, 2012 Yes of course. I howe 10.7.4 in DMG how can I make APP,because I have on USB lion 10.7 but I must have 10.7.4 about my Ivy bridge CPU.
Cassio Posted July 25, 2012 Posted July 25, 2012 It's the same procedure for 10.7 and 10.7.4. About the SATA problem, try this http://www.insanelymac.com/forum/index.php?showtopic=280062&view=findpost&p=1834431 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
artur-pt Posted July 29, 2012 Posted July 29, 2012 hello that happens in mac os x lion version ? try to use the appleacpiplatform from snow leopard good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
goksi75 Posted July 29, 2012 Author Posted July 29, 2012 Yes that happens in mac os x lion version and what to do please tell me
artur-pt Posted July 29, 2012 Posted July 29, 2012 hello is that lion 10.7.0 ? good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
goksi75 Posted July 30, 2012 Author Posted July 30, 2012 Ok now is mountain lion and have this,what to do
Cassio Posted July 30, 2012 Posted July 30, 2012 Are you using NullCPUPM? You need it until you sort things out (SMBIOS, SSDT, AICPMPatch, etc). -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Cassio Posted July 30, 2012 Posted July 30, 2012 NullCPUPM is a temporary fix, you should read about power management. http://Olarila.com/forum/viewtopic.php?f=2&t=34 Soon we will translate this topic, for now use Google translator. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Cassio Posted August 1, 2012 Posted August 1, 2012 Topic in english http://Olarila.com/forum/viewtopic.php?f=18&t=1703 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
