Extopia Posted July 16, 2012 Posted July 16, 2012 Hello , I have installed A hackintosh today [snowLeopard] , and i have some problems First problem : I have doing everything this says and my hackintosh worked fine http://Olarila.com/forum/viewtopic.php?f=16&t=135 , after I shutdown and open , it loads up and makes me choose my Hard Disk , then i loads up a bit and then crashes with an error saying :[Hold down your shutdown key until the hardware is off] . Second Problem : I have no sound , i tried some kexts and drivers and i still have no sound , i tried unplugging and plugging my headset through out all my Sound Plugs and didnt had sound. Third problem : Whenever i press Finder then Software update and download , when it finishes it says unable to use update or something like that . That prevents me from updating my hackintosh to lion and playing some games. Those are all my problems , other wise it works fine , I installed some kexts to make my Graphics Card work to have all the display resolutions and full High Def Screen and i am using it right now . Greetings, Extopia
Cassio Posted July 16, 2012 Posted July 16, 2012 Use boot verbose (-v) to find reason of kernel panic. Post your hardware specs as well. Sound http://Olarila.com/forum/viewtopic.php?f=18&t=454 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Extopia Posted July 16, 2012 Author Posted July 16, 2012 1st its not a panic error , its an apple error , I can provide pictures if asked My specs are : GraphicsCard:9500GT Ram:4GB[Going for an upgrade soon] Processor:GA-EP41-UD3L SystemType:32Bit Thx for ur Audio Problem help , it made my usb headset work but my normal paneled headset didnt work , i have 2 panel jacks in the front and 6 in the back , the front ones dont work , and i have try to put the plug in every single Panel jack and still didnt work This is the error without Verbose : http://lh.rs/RsruDuduqAkq With Verbose : http://lh.rs/PTo0B2DwbJUf
Cassio Posted July 16, 2012 Posted July 16, 2012 Do you have patched dsdt.aml in /Extra? Use kext NullCPUPowerManagement while you don't have patched dsdt.aml and other PM configs set up. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Extopia Posted July 16, 2012 Author Posted July 16, 2012 I have put the Kext using Kext Wizard and the problem is fixed thank u 2 problem left to EDIT : Turns out that the updating and sound is fixed , now to installing lion, which i dont know how , cuz i didnt understand a thing out of the tut u and iHackntosh made Greetings, Extopia
artur-pt Posted July 17, 2012 Posted July 17, 2012 hello to install lion download the iso image enter in forum irc and type ? liondvd burn the iso at slowest speed and boot good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
