This Guide support
Clover and Opencore:poke
Check Guide's Carefully
1.Required Tools
Hackintool
PlistEditor pro
Clover & Oc Configurator
Supported kexts
Broadcom cards Required this kexts:cap
Download Kexts Here
https://github.com/acidanthera/AirportBrcmFixup/releases
https://github.com/acidanthera/BrcmPatchRAM/releases
Supported Cards DW1830,DW1560,DW1820A
                                  KEXTS PATH:guitar
FOR Clover EFI\Clover\Kexts\Others Folder
FOR OpenCore EFI\Kexts Folder Also Need Add Config.plist
Intel cards Required this kexts:frantics
Supported Cards Check Here:wallbash
https://openintelwireless.github.io/itlwm/Compat.html#gen-1
Download Kexts Here:crazy:
https://github.com/OpenIntelWireless/itlwm/releases
https://github.com/OpenIntelWireless/IntelBluetoothFirmware/releases
2.Check Card Path in Hackintool This Same Way For Both BootLoaders:work:
3.Clover Config.plist Injection Method Config.plist\Devices\Properties.
this case my id is 43a0 check your id correctly like Hackintool Red Arrow Mark
After this Save Reboot check Wifi:meeting
4.Open Core Config.plist Injection Method Config.plist\Device Properties. Also Need Add Config.plist Kernels This kexts ,?
Kexts List Oc Config.plist For BCM Cards:help
Kexts List Oc Config.plist For Intel Cards
Save Reboot Check Wifi Enjoy:guitar
Note:Intel Wifi Have Few Problem in Hackintosh kernal Panic & Not Stable Etc If You Have Problem Report Kext Developers in GitHub:wallbash
Quote
    <key>PciRoot(0x0)/Pci(0x1B,0x3)/Pci(0x0,0x0)</key>
                <dict>
                    <key>AAPL,slot-name</key>
                    <string>Internal@0,27,3/0,0</string>
                    <key>compatible</key>
                    <string>pci14e4,43a0</string>
                    <key>device_type</key>
                    <string>Airport Extreme</string>
                    <key>model</key>
                    <string>DW1560 (BCM4352) 802.11ac Wireless</string>
                </dict>
For Donation:
https://tinyurl.com/r7fchn9
Credits and Thanks, MaLd0n, Acidanthera, zxystd, Andres, daliansky and Many Others and  Kexts Developers
  • Like 2
Tried with intel WIFI BT card on Desktop, and BCM4352 card on laptop.
Booth black screen after Opencore picker ? probably doing something wrong.
Haswell Hackintosh: GA Z970N WIFI Gaming 5, i7 4790K, Radeon HD 7970, 16GB RAM
Coffee Lake Hackintosh: GA Z370N Wifi, i7 8700K, Radeon XFX RX Vega 64, 32GB RAM
this card need fake device id. use 43a0
fot bt use BlueToolFixup.kext, BrcmFirmwareData.kext, BrcmPatchRAM3.kext
I use 43a0 but system shows 0x43b1, my card is DW1560 which is Broadcom BCM94352Z, I think ?
this guide says "check your id correctly", and my card id correctly is 0x43b1.
WIFI work good with "AirportBrcmFixup" but "AirPortBrcm4360" plugin must be disabled, this plugin cause black screen.
Bluetooth works the same with only "BlueToolFixup", or  "BlueToolFixup, BrcmFirmwareData, BrcmPatchRAM3".
I have BT icon in settings, AirDrop share works from iPhone to laptop but not from laptop to iPhone.
Hello, my AX201 doesn't show on Hackintool.
I'm on Big Sur and WiFi and BT doesn't works. WiFi has symbol to switch ON/OFF but BT doesn't.
For BT I will buy BT dongle or fixing it.
this section for PCI-e slot right?
4 hours ago, Julio Ueda said:
Uma pergunta, este guia funciona para o Bcm94360cd no monterrey 12.6?
esse é nativo
This unfortunately does not work for my x99 board. My Wireless device works perfectly. It shows in the Pci section of the Hackintool.
My bluetooth device shows up in the usb section of the Hacking tool.
Motherboard: Asus Rog Rampage V Edition 10 x99
Type:XHCI
LocationID: 0x14600000
Port:0x06
Connector: USB3
DevSpeed: 12Mbps
Device: BCM20702A0
How would i got about getting the bluetooth to work as it is needed for the complete AirDrop suite.
The current kexts i have installed: AirportBrcmFixup.kext BrcmBluetoothhInjector.kext BrcmFirmwareData.kext BrcmPatchRAM3.kext
EDIT: Should i enable the EHCI in the bios, as my board has it disabled by default, i can enable it for "unsupported os's"
Edited by iNeedHelp
not xhci but ehci
Using Sonoma 14.2 on Acer 515 55-76
using these kexts and EFI.Opencore.NoteBook.IceLake.MOD
Audio and Wifi all work fine even keyboard shortcuts for Volume and Screen Switching.
The only issue is the Intel Bluetooth not working, It doesn't even show up in the hardware.
how to resolve BT issues? scan devices can connect but disconnect immediatly and can not connect again
Asus Vivobook X512DA Ventura 13.7.8 (Works like a charm)
Lenovo ideapad Z710|Sequoia 15.7.8
Desktop: Asus Z97-C|CPU intel i7 4770K|Nvidia GT 720 2GB|Sequoia 15.7.8| OC 1.0.7
Mac Mini Mid 2010|Sequioa 15.7.8
Nucintosh NUC5i3ryk|Sequoia 15.7.8
Iphone 14 128GB ios 26.5
