Skylake : Intel HD 530: Dual Monitor not working
Previous Thread:
Hi,
Here are my specs
It's a Dell Precision Tower 3620 (G9L5HK2).
Intel Core i7-6700
Intel HD 530
Nvidia Quadro M4000 (Removed, so IGPU only)
Chipset Intel C236 (100 series)
Intel Ethernet I219-LM
Realtek Audio ALC3861
The motherboard has 2 DP ports and 1 HDMI port.
Alone I have 1 DP port working and 1 HDMI port working. I need to reboot to switch port and they don't work used together. If I boot with the 2 monitors connected, only the DP monitor works. Second monitor doesn't appear to be recognized by the OS.
I do use Whatevergeen and Lilu. I'm running the latest clover version.
When HDMI port is connected, this is what it displays in Hackintool :
When I use Display Port:
What I have tried so far:
<dict>
  <data>AAAwAQ==</data>
  <key>framebuffer-fbmem</key>
  <data>AACQAA==</data>
  <key>device_type</key>
  <string>VGA compatible controller</string>
  <key>hda-gfx</key>
  <string>onboard-1</string>
  <key>enable-hdmi-dividers-fix</key>
  <data>AQAAAA==</data>
  <key>framebuffer-con1-type</key>
  <data>AAgAAA==</data>
  <key>AAPL,slot-name</key>
  <string>Internal@0,2,0</string>
  <data>AAASGQ==</data>
  <key>force-online</key>
  <key>model</key>
  <string>Intel HD Graphics 530</string>
  <key>framebuffer-unifiedmem</key>
  <data>AAAAgA==</data>
</dict>
and this with igfxonln=1
<dict>
  <data>
    AAAbGQ==
  </data>
  <key>device-id</key>
  <data>
    GxkAAA==
  </data>
  <data>
    AACQAA==
  </data>
  <data>
    AQAAAA==
  </data>
  <data>
    AAAwAQ==
  </data>
</dict>
Results are the same
Here is a RunMe/SendMe https://www.sendspace.com/file/rkw6uq
Edit: I also noticed one thing: when using display port, I turn off the monitor or disconnect it, it won't turn back on, but HDMI yes.
Thank you
James
Edited by jamesst20
first lego to one fine tune. extract one sendme with this folder. reset nvram with f11 key in boot screen one time
the best in this case is one AMD RX560 or Nvidia 710. intelhd 530 sleep and other little things don't work
Thanks for the quick reply, I deleted my clover folder and pasted yours then rebooted. I got a kernel panic (com.apple.driver.AppleIntelSKLGraphicsFramebuffer) so I had in Clover to put in ig-platform-id 0x12345678. Obviously I have no graphics acceleration but I ran the RunMe.
Here it is : https://www.sendspace.com/file/l7dnpv
openc hackintool and create one patch with these options
hard patch
hard patch
So I applied this
			<dict>
				<key>AAPL,GfxYTile</key>
				<data>
				AQAAAA==
				</data>
				<data>
				AAAbGQ==
				</data>
				<key>enable-hdmi20</key>
				<data>
				AQAAAA==
				</data>
				<data>
				AQAAAA==
				</data>
				<data>
				AAgAAA==
				</data>
				<data>
				AQAAAA==
				</data>
				<key>framebuffer-con2-type</key>
				<data>
				AAgAAA==
				</data>
				<data>
				AACQAA==
				</data>
				<data>
				AQAAAA==
				</data>
				<data>
				AAAwAQ==
				</data>
				<data>
				AAAAgA==
				</data>
				<key>hda-gfx</key>
				<key>model</key>
			</dict>
and sadly didn't do much of a difference :(
New SendMe : https://www.sendspace.com/file/mqgcar
bro, put one nvidia 710 or amd rx560 gigabyte (prefer rx560)
all start work after that, sleep, hardware accel via DGPU with iMacPro1,1 and shikigva=128 smbios, dual monitor+, etc
the config looks very good, just need it
Thanks for the help. I was thinking it would end up this way. Actually I am building this hackintosh for a friend of mine, I will finish the setup and let him know he won't have dual-monitor and sleep until he get a native AMD GPU supported.
Would you be able to generate me the "best" configuration for this PC ?
Edited by jamesst20
save this efi folder and just put amd card and done ;)
if have problems just post here
I went for the ASUS RX 480 OC 4GB. Works flawless.
Edited by jamesst20
Good! ;)
