problem in activating the Wi-Fi card (BCM943228HMB)
Good evening everyone
I installed a BigSur Beta 8 on my laptop HP ProBook 650 G1
The problem that remained is the activation of the Wi-Fi card (BCM943228HMB)
Please help me activate the Wi-Fi card
Thank you in advance
Please excuse me if there are mistakes in the expression because I do not speak the English language. Thank you
use this kext with no plugins
AirportBrcmFixup.kext.zip
and inject dev id 43a0
in my case i'm using it
Quote
Method (_DSM, 4, NotSerialized)  // _DSM: Device-Specific Method
                    If ((Arg2 == Zero))
                        Return (Buffer ()
                             0x03                                             // .
                    Return (Package ()
                        "AAPL,slot-name",
                        "Built In",
                        "built-in",
                        Buffer (One)
                             0x00                                             // .
                        "model",
                        Buffer ()
                            "Broadcom Brcm43xx Wireless Network Adapter"
                        "name",
                        Buffer ()
                            "AirPort Controller"
                        "compatible",
                        Buffer ()
                            "pci14e4,43a0"
                        "device-id",
                        Buffer ()
                             0xA0, 0x43, 0x00, 0x00                           // .C..
                        "IOName",
                        "pci14e4,43a0",
                        "device_type",
                        Buffer (0x10)
                            "AirPort Extreme"
                        "pci-aspm-default",
                        Buffer (One)
                             0x00                                             // .
Hi Maldon, i have same wifi card and I don't know how to do "inject dev id 43a0" I guess I have to add this line to info.plist of the AirportBrcmFixup.kext but next step...I have to add this patch to my ssdt.aml??? thanks.
I have Big Sur also and opencore working perfectly. please any clue? :D thanks a lot!!
DSDT.aml
use patch above with this kext above
Hi Maldon
I tried to patch my ssdt.aml with maciasl but I don't know where I have to patch, do you have a manual or guide to follow??? kext is already copied to my kext folder but I can't patch ssdt.aml. help pleaaaase :D
thanks a lot.
check ioreg what device u need inject _dsm
I have the same card on ProBook 640 G1 how can I use patch above with this kext please helppp
My hardware is: HP ProBook 640 G1
CPU: i3-4000M
GPU: Intel HD 4600 (1366x768)
Wi-Fi: BCM943228HMB
RAM: 4GB + 4GB (1600Mhz)
STORAGE: HDD 500GB
Can inject via device properties too, more better dont need rename _dsm, Just check correct ADR
<key>PciRoot(0x0)/Pci(0x1c,0x1)/Pci(0x0,0x0)</key>
            <dict>
                <key>compatible</key>
                <string>pci14e4,43a0</string>
                <key>#pci-aspm-default</key>
                <integer>0</integer>
            </dict>
@MaLd0n I've saved like this and restarted but not working
Edited by johnwalked
CPU: i3-4000M
Wi-Fi: BCM943228HMB
STORAGE: HDD 500GB
compatible - pci14e4,43a0 - String
I tried all methods bro but no luck, what am I missing?
I've realized this card is not supported at all
CPU: i3-4000M
Wi-Fi: BCM943228HMB
STORAGE: HDD 500GB
Ye. Some cards don't have support under macOS.
I've found this from an old laptop
and I can see it's listed in Inventory of supported cards, can we make this work?
CPU: i3-4000M
Wi-Fi: BCM943228HMB
STORAGE: HDD 500GB
Atheros lose support on new system
I'm on Monterey though it's working up to Ventura right?
CPU: i3-4000M
Wi-Fi: BCM943228HMB
STORAGE: HDD 500GB
i think last native is high sierra
okay thanks and sry if I bothered.
CPU: i3-4000M
Wi-Fi: BCM943228HMB
STORAGE: HDD 500GB
Just enjoy!
