Hackintosh macOS Big Sur and Monterey with Clover bootloader
-Problems with Paypal HERE
-Installation Guide HERE
-Hackintosh EFI folders HERE
-Hackintosh USB Remap HERE
-Why Olarila doesn't support TonyMac, Reedit, Little-Translated and others HERE
Quirks Configuration check HERE
Test with one USB stick bootable.
In some cases need configure Quirks.
Disable CSM in BIOS/UEFI setup
Enjoy!
Credits: Jief_MachakSlice and acidanthera team
Some words from Slice
Since rev5123 devs make joined bootloader Clover+OpenCore. It started as Clover using Clover's GUI and ability to change settings and then started OpenCore to inject and patche kexts and start macOS.
Starting Windows and other OSes is done by Clover's way.
There are new section in config.plist named Quirks that collect setting for OpenCore but some setting is just delegated from Clover because it can change it on the fly.
There is a correspondence of OpenCore and traditional Clover settings to easy migrate from OpenCore to new Clover.
OpenCore                      Clover
AppleCpuPmCfgLock   AppleIntelCPUPM
AppleXcpmCfgLock      KernelPm
DisableRtcChecksum   AppleRTC
LapicKernelPanic          KernelLapic
About kernel and kext patches there is the follow.
1. OC accounts them as same and name "kernel" in the place of name of kext. Clover has different section for Kernel patches, kexts patches and Booter (boot.efi) patches.
2. Clover deal only with 64 bit arch while OC has "Arch" parameter.
Other fields are
OpenCore        Clover
Base                  Procedure
Comment        Comment
Count               Count
Enabled           Disabled
Skip                  Skip
Identifier         Name
Find                  Find
Mask                MaskFind
Replace           Replace
ReplaceMask  MaskReplace
MaxKernel      -
MinKernel       -
-                        MatchOS
-                        InfoPlistPatch
-                        RangeFind
3. Procedure name in OpenCore must be long like __ZN8AppleRTC18setupDateTimeAlarmEPK11RTCDateTime
Clover can use short name. In the example it can be setupDateTimeAlarm.
4. OpenCore assumes byte mask while Clover assumes bit masking. In the case of 0xFF00FF it will be the same. More careful see documentation for OpenCore and samples for Clover at this page.
5. RangeFind restrict search in Clover by several bytes. I don't know if OpenCore is able do the same.
6. Patches in OpenCore can be "Enabled" by setting the variable while in Clover they are enabled by default. User can disable it in the config.plist or in Clover GUI.
7. For Kernel patches we had additional
"StartPattern" and corresponding "MaskStart" to define a place from what we want to search.
OpenCore has no such service. Later we will extend the possibility.
  • Like 5
  • Thanks 2
Hi, I have the same hardware as you gigabyte : GA-H97-D3H, CPU 3.5 GHz Quad-Core Intel Core i5 4460, RAM 16 GB 1333 MHz DDR3
I can install Big Sur with Clover but I can't start, what can you tell me?
yes. user same folder EFI CLOVER BS
Edited by Kankon
Motherboard Asus TUF Z390-PLUS GAMING (WI-FI) CPU 3.6 GHz 8-Core Intel Core i5, Ram 32 GB 3000 MHz DDR4, Graphics : AMD Radeon RX 6700 XT 12 GB OS:MacOS Tahoe 26.0 RC (25A353) SERIE 30, 40 (COOFFELAKE / COMETLAKE
need wait some time. devs have a hard work
The installation card does not move ?
MB: ASUS p6td deluxe
CPU: i7 980x es
RAM: DDR3 1600 4G x5 20G
VGA: R9 270X 2G MSI 570 8G
17 hours ago, 阿文 said:
Edited by 阿文
On 9/24/2020 at 6:14 AM, MaLd0n said:
Clover start work again with BigSur. Thanks to Jief_MachakSlice and acidanthera team
Download Clover Folder BigSur for Desktop Serie 300
Don't use Clover Configurator, use one good plist editor if you need change things in your config.plist.
Enjoy!
it happens because of the boot file EFI / boot / bootx64.efi how to fix
video attached
https://radikal.ru/video/eqYUxXnB9nd
