Hi.
I have a problem starting the installation of Olarila Catalina 10.15.6.
I downloaded the image and generated the pendrive using Balena Etcher portable.
When starting the pendrive and select Boot macOS Install, this appears:
Try all 4 USBs on the notebook and the problem is the same.
Any suggestion?
The notebook has:
CPU: i7 4710MQ
RAM 12GB
video: intel 4600
Edited by Franchute13
Hello MaLd0n.
It worked perfectly.
Now another problem.
When it is installing and there are 2 minutes left to finish it says:
An error occurred while preparing the installation. try running this application again olarila catalina.
Searching the forum I understand that I should apply
EmuVariableUefi or use one full dsdt patched
Is that so?
If so, is there a tutorial on how to apply the EmuVariableUefi?
Regards
Extract tables with F4 key in Clover boot screen, files generated in Clover/Acpi/origin, post here
12 hours ago, Franchute13 said:
Here is the tables.
k
let me know
enjoy
same problem here on 2 minutes left to finish, Mald0n is it possible to have your 10.15.5 image for download thanks
Asus Vivobook X512DA Ventura 13.5 (ventura works like a charm)
Lenovo ideapad Z710 on sequoia 15.7
Desktop: Asus Z97-C|CPU intel i7 4770K|Nvidia GT 720 2GB|Sequoia 15.6.1| OC 1.0.6
Iphone 14 128GB ios 26
boot after 2 minutes freeze dont work? in many cases this error appears but install is finish
No for me install start but before 2 minutes while finish preparing the installation and restart i have the same error message:
Edited by moishiteru
what ur hardware?
DH61AG with i5 2320 (hd 2000 graphic) mojave install works fine but catalina don't, do you think i must change the cpu????
it ok with an old version of catalina
U need use iMac13,2 smbios
put one gpu. rx560
