The HeadHunters Posted August 26, 2020 Posted August 26, 2020 (edited) Can you please tell me which hackintosh is compatible with this hardware - Gigabyte H61M-S2P Rev 3.0 Intel Pentium G2020 Amd Readon 5450 2gb Ram - 4gb Edited August 26, 2020 by The HeadHunters
Administrators MaLd0n Posted August 26, 2020 Administrators Posted August 26, 2020 high sierra. ur gpu need high sierra https://www.olarila.com/topic/6129-useful-links/ 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
The HeadHunters Posted August 27, 2020 Author Posted August 27, 2020 6 hours ago, MaLd0n said: high sierra. ur gpu need high sierra https://www.olarila.com/topic/6129-useful-links/ Which efi folder should i use for this mobo?
Administrators MaLd0n Posted August 27, 2020 Administrators Posted August 27, 2020 serie 6. u need fakecpuid 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
The HeadHunters Posted August 28, 2020 Author Posted August 28, 2020 19 hours ago, MaLd0n said: serie 6. u need fakecpuid Have to do some changes while installing?
Administrators MaLd0n Posted August 28, 2020 Administrators Posted August 28, 2020 2 hours ago, The HeadHunters said: Have to do some changes while installing? first shot in default. if don't work u need changes https://www.olarila.com/topic/5794-hackintosh-guide-install-macos-with-vanilla-olarila-image-step-by-step-install-and-post-install-windows-linux-or-mac/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
The HeadHunters Posted August 28, 2020 Author Posted August 28, 2020 2 hours ago, MaLd0n said: first shot in default. if don't work u need changes https://www.olarila.com/topic/5794-hackintosh-guide-install-macos-with-vanilla-olarila-image-step-by-step-install-and-post-install-windows-linux-or-mac/ Sure
The HeadHunters Posted September 9, 2020 Author Posted September 9, 2020 (edited) On 8/28/2020 at 7:43 PM, MaLd0n said: first shot in default. if don't work u need changes https://www.olarila.com/topic/5794-hackintosh-guide-install-macos-with-vanilla-olarila-image-step-by-step-install-and-post-install-windows-linux-or-mac/ Sir, Ati amd hd5450 showing 3 mb only. Also it isn't booting with your efi folder(series 6) stuck at gigabyte logo. Edited September 9, 2020 by The HeadHunters
The HeadHunters Posted September 10, 2020 Author Posted September 10, 2020 On 8/28/2020 at 7:43 PM, MaLd0n said: first shot in default. if don't work u need changes https://www.olarila.com/topic/5794-hackintosh-guide-install-macos-with-vanilla-olarila-image-step-by-step-install-and-post-install-windows-linux-or-mac/ Sir take a look into it plz?✌️
Administrators MaLd0n Posted September 10, 2020 Administrators Posted September 10, 2020 On 9/9/2020 at 7:54 AM, The HeadHunters said: Also it isn't booting with your efi folder(series 6) stuck at gigabyte logo. use aptiomemoryfix instead oc quirks or configure quirks -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
The HeadHunters Posted September 11, 2020 Author Posted September 11, 2020 (edited) 9 hours ago, MaLd0n said: use aptiomemoryfix instead oc quirks or configure quirks From where i get the file? And for graphic card? Edited September 11, 2020 by The HeadHunters
Administrators MaLd0n Posted September 11, 2020 Administrators Posted September 11, 2020 https://www.olarila.com/applications/core/interface/file/attachment.php?id=29633 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
The HeadHunters Posted September 11, 2020 Author Posted September 11, 2020 15 minutes ago, MaLd0n said: https://www.olarila.com/applications/core/interface/file/attachment.php?id=29633 70.48 kB · 256 downloads Fix for graphics also?
Administrators MaLd0n Posted September 11, 2020 Administrators Posted September 11, 2020 i never use this card u need check that -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
The HeadHunters Posted September 11, 2020 Author Posted September 11, 2020 1 hour ago, MaLd0n said: i never use this card u need check that I fixed this card issue in Osx Lion....can i use those kexts in high sierra also?
Administrators MaLd0n Posted September 11, 2020 Administrators Posted September 11, 2020 i think u dont need. high sierra have support for ur card. just check it -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
The HeadHunters Posted September 12, 2020 Author Posted September 12, 2020 7 hours ago, MaLd0n said: i think u dont need. high sierra have support for ur card. just check it But it's showing 3mb only
Administrators MaLd0n Posted September 12, 2020 Administrators Posted September 12, 2020 check a fake dev id for ur card -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
The HeadHunters Posted September 12, 2020 Author Posted September 12, 2020 6 hours ago, MaLd0n said: check a fake dev id for ur card Not working... Should i try any lower version?
Administrators MaLd0n Posted September 12, 2020 Administrators Posted September 12, 2020 u try inject that ? 0x68E01002 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
