[SOLVED] Stuck at : couldn't alloc class "RTL8111" (SFF 8565U / UHD 620 / ALC892)
inject device ec
clover or opencore?
use this ssdt
SSDT-OLARILA.aml.zip
with this acpi patch
Quote
<dict>
                    <key>Find</key>
                    <data>RUMwXw==</data>
                    <key>Replace</key>
                    <data>RUNfXw==</data>
                    <key>Disabled</key>
                    <false/>
                    <key>Comment</key>
                    <string>EC0 to EC</string>
                </dict>
Use Mieze kext, check insanelymac or github
Have tried that, network adapter is seen (same as with stock kext of the image), but cable is said to be disconnectd (same machine finds network properly under a Live Ubuntu so I'm sure there is no cable issue there).
No display whatsoever, I have tried various connectors configs and NVRAM options, display wont turn on after initial boot. Shall I post output of runme here ?
No audio device at all (but I'm still booting on the install usb)
Thank you,
