Hello,
I followed the guide
and take https://www.olarila.com/applications/core/interface/file/attachment.php?id=27878  EFI folder
I try all the tips found on the net ... I just block it and nothing helps, I can't really find similar topics on the internet.
I can not put in photo format it put the linkhttps://zupimages.net/viewer.php?id=20/34/xr3k.jpg (ERROR IMAGE)
Thanks in advance and sry for my english ?  !
EDIT : I try GraphicsEnabler=No but bootloop
EDIT2 :
- ASUS CROSSHAIR HERO VI
- Ryzen 1600
- RX480 8Go
Edited by Mickael Deceire
big sur is a good fight for all ;)
u injected device EC?
I try : change EC0 to EC ;change H_EC to EC; change ECDV to EC
I try SSDT-EC patch for Ryzen
The procedure resolves the pci error but adds "AMDCPUSupport::startWorkLoop initialize serviceAMDCPUSupport::setupKeysVsmc: VirtualSMCAPI::addKey succeed!"; which is I think solved by the SSDT-EC but it is not working. I still have a low level in hackintosh
I can't find anything on google about it
If you are on beta 5, try to disable AMDRyzenCPUPowerManagement.kext
AMD Ryzen 9 3900X
ASUS ROG STRIX X570-E GAMING
Sapphire Nitro+ Radeon RX 590 8GB
CORSAIR Vengeance LPX 32GB DDR4 3600Mhz
