lukeslater Posted May 9, 2022 Posted May 9, 2022 (edited) Hi, here is my dumo file. Edited DSDT would be appreciated. I donated via PayPal. System is Gigabyte z490 Vision D with AMD Radeon 6900XT, Broadcom BCM43xx Wifi Adapter, Highpoint 3720 Raid controller. Thank you Edited May 10, 2022 by lukeslater
Administrators MaLd0n Posted May 9, 2022 Author Administrators Posted May 9, 2022 42 minutes ago, lukeslater said: Hi remove ssdts and select rebase regions in acpi tab DSDT.aml.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
lukeslater Posted May 10, 2022 Posted May 10, 2022 23 hours ago, MaLd0n said: remove ssdts and select rebase regions in acpi tab DSDT.aml.zip 46.21 kB · 1 download Thanks, worked. Do I have to remove the entries in device properties?
rkpz81 Posted February 16, 2023 Posted February 16, 2023 I'm giving this build a try soon (feb-2023) any updates or anything you would do differently?
Administrators MaLd0n Posted February 16, 2023 Author Administrators Posted February 16, 2023 https://www.olarila.com/topic/25111-hackintosh-efi-folders-for-all-chipsets-with-opencore-mod/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Alexander Sharkey Posted April 29, 2023 Posted April 29, 2023 Hi there, PM'd you my donation Here is my run me log https://www.dropbox.com/sh/6acbp401w29jut8/AADAN6Ql19HCYohF_Ky85tzda?dl=0 I've put my USB Map kext in there as well as I've disabled certain usb2 ports for limitations with z490 vision d Been using with goods success dortania and open core guides from CaseyCJ/Schmocklord to base my open core plist. But recently lost hot plug with TB3 after successfully patching the TB3 controller. I was wanting Thunderbolt Bridge to directly connect 2 TB hacks. Problem was my TB4 OWC dock no longer worked with the TB3 controller. So I reverted back to the original ROM on the Z490 board which I backed up before flashing. Really just trying to get TB3 hot plug devices back working (which did in the past - owc nvme enclosure, black magic 3g recorder). USB devices can hot plug on the TB3 ports, just not genuine TB3 devices. Running Big Sur as an iMac 20,2 i910900k PCI E DEVICES: x16 - 5900XT x 8 - Aquatina 10GbE x 1 - Fenvi T919 x 4 - 4 port Sata (I have 2 NVME drives installed and 8 HDD's) Appreciate any help
