24 minutes ago, mikeskynard said:
Hello MaLd0n
8 hours ago, Vladimir K said:
1. What can you say about the Gigabyte Z490 Vision G?
2. Can i7 10700 processor be used without K index?
1- Very Nice. U can use any mobo, h410 or high
2- Very nice too
Hello mald0n,
I followed the guide for the usb, but some ports are not seen by hackintool, yet the usb key works, is this normal?
use USBInjectAll.kext / XHCI-unsupported.kext and generate ssdt uiac
4 minutes ago, DGReM said:
Waiting for the DSDT :)
--UPDATE FIRST POST--
New Clover EFI Folder with last version
New Opencore EFI Folder with last version
36 minutes ago, DeJoTaDeEmE said:
i edited ur files, no? use same
If they are in my old equipment, recently I have bought new equipment with the characteristics of this post, except for the refrigeration that I put a different one
,the other team broke the bios every so often.
Edited by DeJoTaDeEmE
Hi, MaLd0n !
I got new build with GA Z490 Vision D and I5-10400.
I used files from this topic.
System loaded without problems but the list of devices that I see is different from the one in the screenshot.
Thunderbolt and built-in Wi-Fi doesn't work.
Can you help me?
Thank you!
u need a full dsdt patched
3 minutes ago, Volosandro said:
Can you share previous version of DSDT from this topic?
old bios/uefi version
update to last version and post here
3 hours ago, Volosandro said:
Thank you for answer.
u need update bios/uefi to last version and remove edited dsdt in clover/acpi/patched folder, reboot and extract
22 minutes ago, Volosandro said:
Done.
22 hours ago, MaLd0n said:
Hi!
Today i tried to connect a sound card UAD Apollo Arrow Thunderbolt but get error "Cannot use Thunderbolt accessory. Thunderbolt accessories are not supported on this Mac".
Tried to change SMBios to iMac20,1 and get same error.
Can you give some ideas how to fix it?  Сan this be due to the fact that the TB3-card is not defined as onboard?
Edit: checked in Hackintool - in case when TB3 device connected before power on it defined as connected to USB3 connector.
Thank you.
Edited by Volosandro
these errors is not common. use a fresh install and check
