Help kernel panic HP dv6-3016sl
Joyfult
Hi everybody! I'm trying to install snow leopard on my dv6-3016sl. I insert iBoot and swipe it with the Snow Leopard dvd. The problem is that everytime appear the kernel panic.. something about ACPI. So I tried to install it on other 2 laptops (one acer and one lenovo) and it appear always the same error. So is not a problem of my laptop.Please somebody help me. Thanks in advance
Link to comment
Share on other sites
Hi, try with snow leopard 10.6.3 retail and nawcom mod cd.... and if gives kernel panic,post a photo.....
Asus P7H55M PRO Core i7 2.81 GHz RAM 8 GB 1333 MHz DDR3 AMD 6990 Dual GPU 4 GB DDR5 OS X 10.10.3 Toshiba TV 42* 1920x1080 Samsung SyncMaster 22* 1920x1080 Apple Cinema Display 20ª
Link to comment
If it doesn't work with ModCD and cpus=1 try Mammoth boot CD
http://www.insanelymac.com/forum/index.php?showtopic=250849
You need lapic kernel (Taptun).
-Donations-
PayPal HERE - Stripe HERE - BuyMeaCoffee HERE - Mercado Livre HERE
Skrill danielnmaldonado@gmail.com - BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3
PicPay @danielnmaldonado - PiX @danielnmaldonado@gmail.com
Link to comment
I tryied with retail SL 10.6 and nawcom modcd and when it says press any butto to continue, it reboot my system and nothing happen...
Link to comment
With normal boot CDs (without lapic kernel) you need to type "cpus=1 -v" before pressing enter at the boot menu.
-Donations-
Link to comment
Explain what? I told you twice, if the boot CD does not contain the "lapic kernel" you need to use the boot flag "cpus=1".
-Donations-
Link to comment
