So, I just installed macOS Big Sur Beta 4 on my Ideapad S340-14IWL. The installation went well. The problem was coming while I try to add VoodooI2C kext to activate my Touchpad. While booting, it got kernel panic on verbose screen:
Refus new kext : a prelinked copy with different executable UUID is already present.
I knew, that the KP is caused by the plugin on voodooi2c/voodoops2controller, VoodooInput. While I remove the kext, the KP is gone. But I can't activate my I2C Touchpad or use ps2 keyboard on laptop(since the kext was removed).
VoodooInput used as plugin on 2 kext, voodoops2controller and voodooi2c, but can they work together as plugin without causing KP?
20200810_054341.zip
voodooinput from i2c or ps2 project?
Not sure from which one. It's look like theyre can't work together of put on same folder. First I put ps2, the system is fine. Then I add voodooi2c, the KP is exist. Or vice versa.
what are you using as boot loader Opencore or Clover?
