InnocentAlone Posted August 20, 2020 Posted August 20, 2020 5 hours ago, Athirne said: Got it working last night after another try. Had to grab a fresh image, used the latest 0.6.1 build from mid this month, and disable the vsmcgen and the two booter-* switch. After a in place upgrade and a NVRAM reset after the upgrade was done all was good. Just let it update at its own pace took a loooong time (about an hour). Deep sleep isnt working and bugs but time to try Beta 5 next. Hello, I own Legion Y530. You have the same? If yes, can you please give your Efi folder? i want to try Big sur...
