11 minutes ago, Márcio Castro said:
Bom dia mano, por favor tem como me ajudar. Já mudei a smbios e nada fiz o que vc pediu não deu certo, no 3,4 beta acontece isso. Tenho uma partição com o catalina e o big sur em outra.
esse erro é do smbios errado, tentar instalar o Xcode dev tools se der erro 100 % ctz que é SMBIOS.
lembrando que com o Big Sur o smbios teve um drop em alguns Mac,  leia a documentação,
Edited by Dean91
CPU i5-6500    Motherboard ASUS H110M-A/M.2    RAM 16GB  IGPU Intel HD 530   GPU GTX1060 (Disable)
19 hours ago, Cclown98 said:
i'm using a fenvi t919 which uses BCM94360CD
remember to reset your nvram after every change you can also try disabling (removing) vsmcgen=1 from your args
The problem was solved as you suggested with OC 6.1. Thanks a lot.
valeu mano  vou tentar
After a few days of not being able to get this to work I gave up and had to go back to 10.15.6 and enjoy having my 10baseT nic back for the first time since I started using the betas. It seems like it would either fail on loading a system file and loop or failing to bring up the framebuffer (Vega Radeon VII).
NVRAM reset and removing some of the variables (like vsmcgen=1) and trying the 0.6.1 OC config didnt fix it for me.
Sad since a modified version of the OC config from Beta 2 worked like a champ for me across both it and Beta 3 with no tweaks (just keep kexts up to date)
Asrock Z390 Taichi /w 9770k & Radeon VII GPU. Official AirPort Extreme  (0x14E4, 0x111), Aquantia AQC107 based NIC.
Just sharing my results for anyone with a similar config, may try again in Beta 5, but right now I need to get a bunch of work done since I lost a bit to troubleshooting.
enato amigo nada ainda, nao sei o que acontece que parecec nao achou o servidor do id apple. se vc tiver qual quer outra solucao seria grato pela sua ajuda e conhecimento
posta sua config e a versão do clover que esta usando
Edited by Dean91
BigSur Beta  4
VoodooPs2Controller.kext not working.But Beta 3 working well
How  I fix it?
My laptop=lenovo y530
Opencore 0.6.0
i5 8500
Intel UHD630
Edited by sanyaaahtconex
Unusual request Big sur installing in Russian after downloading your EFI folder ?
goes all the way to the final insall but its in Russian, my old efi folder (same usb drive install is in Eng) so
logic dictates that since beta three installed with version opencore 60 in Eng
then summery opencore 61 from your efi folders (download) installs in Russ, how to change ?
stay work here. just fine
i think u need reset nvram. my premade folder prev-lang:kbd = nothing
estou usando Big Sur beta 4 em um notebook acer e1 571
i5 Intel(R) Core(TM) i5-3230M CPU @ 2.60GHz
Ivy Bridge
opencore 6.0.0
intel HD Graphics 4000 1536 MB
6bg memoria
config.plist.zip
tentei varias coisas mais nada, não acho como ativar a placa de wifi pois não tem Kext pra esse bibi Sur
no catalina usava atheros AR9485, MAIS NO Big Sur DA PANICO NAO SOBE
Edited by Márcio Castro
Ivy Bridge
opencore 6.0.0
6bg memoria
Sua SMBIOS é MacBookPro10,2
Thanks, MaLdOn for all the work and posts that go into your site.  It has helped a lot, especially your catalina iso.
Big Sur is a lot harder to boot.  Have tried the EFI PREMADE CLOVER from your EFI page, but was not able to boot DP4 with it.  Alternatively, tried to modify clover with the bootx64.efi and cloverx64.efi/QcQuirks/OpenRuntime.efi but that also would not boot DP4.  Also tried using the SSDT-OLA.aml but that did not prevent boot hang or KP.  The CLOVER.NOTEBOOKS.100.200.300 and OPENCORE.NOTEBOOKS.100.200.300 EFIs from your EFI page appear to be for booting pre-Big Sur.
Have HP laptop/Skylake/i5/520/sunrise.  Lapic and UnblockFsConnect enabled for OC, but boot fails with KP.
Have also found that OC with VirtualSMC freezes the boot, but FakeSMC appears to boot further but also fails with KP.
Not sure if KP issue is specific to HP laptops/if doing something wrong.
Have followed Skylake OC tutorial, Catalina booting fine.
Have included a txt file OC generates with KP.
Would an lspci -k from linux help?
If there are special configs for OC or Clover on HP laptop please tell me what needs to be done for booting BS DP4 installer.
Thank you.
ola.zip
1 hour ago, EnriqueV said:
big sur is a mistery
On 8/4/2020 at 8:10 PM, caracortada7883 said:
i downloaded the image with gibMacOS and installed without issue
How did you do that? I've been trying but I only get the latest catalina
check here first part
https://www.olarila.com/topic/9530-install-macos-catalina-big-sur-on-mobos-serie-400-with-intel-10th-desktop-processors-using-opencore-or-clover-bootloader/
1 hour ago, 阿文 said:
asus p6td deluxe X58  USB OC EFI BIG sur NO ?
Got it working last night after another try. Had to grab a fresh image, used the latest 0.6.1 build from mid this month, and disable the vsmcgen and the two booter-* switch. After a in place upgrade and a NVRAM reset after the upgrade was done all was good. Just let it update at its own pace took a loooong time (about an hour). Deep sleep isnt working and bugs but time to try Beta 5 next. :-)
