Help on enabling audio on my laptop
I have problem of enabling audio in my Broadwell laptop.
The audio device's model is Conxent SmartAudio HD. Codec is CX20751.
The problem is, When I use AppleALC and set boot arguments, in Hackintool, it doesn't even get the device name and codec. The audio section is just empty
When I use VoodooHDA, it does recognizes Device, Sub device, and name. But doesn't recognizes codec and revision. Therefore no audio.
Here is the result of runme.app. What is the problem?
https://filebin.net/cuyw9awx1xjjtwya
But it doesn't work.
I have put alcid=3, alcid=21 alcid=28
Nothing works
3 hours ago, MaLd0n said:
Even if I set alcid=xx, hackintool doesn't recognize my sound card. The sound section is empty
It did recognize my sound card on prebuilt olarila image. But the image is clover. And I want to use opencore. So, what may be the problem?
Edited by 나수환
u need replace xx with layout
24 minutes ago, ShivaSoftee said:
I have used all layouts with same conxent cx20751, used applealc, audio driver detected in Hackintool but not showing in output. Please help.
https://www.olarila.com/topic/6074-guide-easy-audio-solution-with-applealc-clover-and-opencore/
Check here:https://www.tonymacx86.com/threads/applehda-problems-conexant-cx20751-2.191391/. This might lead to solving your issue.
