Stuck at: “Forcing CS_RUNTIME for entitlements: com.apple.rootless.restriced-block-devices
Hi
So i tried to install big sur beta 3 on my pc and booted into recovery, i erased my disk and started downloading it. But after sometimes, i got stuck on this: https://drive.google.com/file/d/1La6hVoKi8lIeP_BAdmuso3VEXcCgHgcy
What i did:
I disabled whatevergreen with opencore configurator, added agdpmod=pikera and disabled serial port (superio)
My specs:
I7 7700
Gigabyte RX 5600 OC
Gigabyte H270M-D3H (Not sure)
Hopefully there should be any way to fix this...
use my premade efi folder
1 hour ago, Ariel Sasson said:
Hi
What i did:
My specs:
I7 7700
Gigabyte RX 5600 OC
wait about  20 to 30 minutes at this stage
  • Thanks 1
Well, the problem was that i forgot to disable gfx firmware on the argument and after adding it finally it booted
But now my ethernet is not working  (on catalina it worked)
https://drive.google.com/file/d/15pBw5Vwr8Bn0kQ4LNFexOkKkALpH_vRK/view?usp=drivesdk
I know its a realtek lan and the kexts are not detecting it anyways
Edited by Ariel Sasson
some people report 2 hours lol
yes
