stakeout5 Posted August 1, 2020 Posted August 1, 2020 Hello! I keep having a lot of kernel panics trying to get Big Sur Beta 3 to boot on my Zenbook. I was wondering if you have a Premade EFI That you think would work with: i5-7200U HD 620 Thank you! This is my error I cannot get past: https://photos.app.goo.gl/7nSr9SHcdTahusU47 And here is the EFI Ive been using / trying to get to work. The DSDT is from what you had written for me from Catalina. Thanks! Big Sur Test EFI.zip
Administrators MaLd0n Posted August 1, 2020 Administrators Posted August 1, 2020 use minimal kext for install bigsur -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
stakeout5 Posted August 1, 2020 Author Posted August 1, 2020 yes, thank you! New issue here : (. I have had this issue since Beta 1
Administrators MaLd0n Posted August 2, 2020 Administrators Posted August 2, 2020 16 hours ago, stakeout5 said: yes, thank you! New issue here : (. I have had this issue since Beta 1 k -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
JIMULAY Posted August 3, 2020 Posted August 3, 2020 On 8/2/2020 at 12:19 AM, stakeout5 said: Hello! I keep having a lot of kernel panics trying to get Big Sur Beta 3 to boot on my Zenbook. I was wondering if you have a Premade EFI That you think would work with: i5-7200U HD 620 Thank you! This is my error I cannot get past: https://photos.app.goo.gl/7nSr9SHcdTahusU47 And here is the EFI Ive been using / trying to get to work. The DSDT is from what you had written for me from Catalina. Thanks! Big Sur Test EFI.zip 3.33 MB · 6 downloads how you solved the panic error? 1
Administrators MaLd0n Posted August 3, 2020 Administrators Posted August 3, 2020 14 hours ago, Aamir khan swati said: how you solved the panic error? use a minimal kexts -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
bisaalz Posted September 14, 2020 Posted September 14, 2020 (edited) Bro how did you do it And what is minimal kext Can u please provide the efi for kabylake i5 7200u for big sur Edited September 14, 2020 by bisaalz
Administrators MaLd0n Posted September 14, 2020 Administrators Posted September 14, 2020 lilu, virtualsmc, whatevergreen -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
mixha_m Posted October 28, 2020 Posted October 28, 2020 Hi @MaLd0n please help, my igpu UHD620 Kabylake i5 - 7200U only read 7 Mb in BigSur Opencore config.plist.zip
tasco11 Posted October 28, 2020 Posted October 28, 2020 18 minutes ago, mixha_m said: Hi @MaLd0n please help, my igpu UHD620 Kabylake i5 - 7200U only read 7 Mb in BigSur Opencore config.plist.zip 4.3 kB · 0 downloads Inject framebuffer properties visa config.plist or DSDT
Administrators MaLd0n Posted October 29, 2020 Administrators Posted October 29, 2020 <key>PciRoot(0)/Pci(0x02,0)</key> <dict> <key>AAPL,ig-platform-id</key> <data>AADAhw==</data> <key>device-id</key> <data>FlkAAA==</data> <key>framebuffer-con1-alldata</key> <data>AQUJAAAIAACHAQAA</data> <key>framebuffer-con1-enable</key> <data>AQAAAA==</data> <key>framebuffer-con2-alldata</key> <string><02040a00 00080000 87010000></string> <key>framebuffer-con2-enable</key> <data>AQAAAA==</data> <key>framebuffer-fbmem</key> <data>AACQAA==</data> <key>framebuffer-patch-enable</key> <data>AQAAAA==</data> <key>framebuffer-stolenmem</key> <data>AAAwAQ==</data> </dict> -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
mixha_m Posted October 30, 2020 Posted October 30, 2020 On 10/29/2020 at 8:11 AM, MaLd0n said: <key>PciRoot(0)/Pci(0x02,0)</key> <dict> <key>AAPL,ig-platform-id</key> <data>AADAhw==</data> <key>device-id</key> <data>FlkAAA==</data> <key>framebuffer-con1-alldata</key> <data>AQUJAAAIAACHAQAA</data> <key>framebuffer-con1-enable</key> <data>AQAAAA==</data> <key>framebuffer-con2-alldata</key> <string><02040a00 00080000 87010000></string> <key>framebuffer-con2-enable</key> <data>AQAAAA==</data> <key>framebuffer-fbmem</key> <data>AACQAA==</data> <key>framebuffer-patch-enable</key> <data>AQAAAA==</data> <key>framebuffer-stolenmem</key> <data>AAAwAQ==</data> </dict> Thanks @MaLd0n
