anto barreca Posted May 13, 2021 Posted May 13, 2021 44 minutes ago, MsujE said: same disk. Only 1 disk for three OS. I have drivers problems in windows and ubuntu when booting from Opencore config try to change like this in the plist, maybe it can help Kernel> Quirks> CustomSMBIOSGuid> True (default is False) PlatformInfo> UpdateSMBIOSMode> Custom (default is Create)
MsujE Posted May 13, 2021 Posted May 13, 2021 58 minutes ago, anto barreca said: try to change like this in the plist, maybe it can help Kernel> Quirks> CustomSMBIOSGuid> True (default is False) PlatformInfo> UpdateSMBIOSMode> Custom (default is Create) I tried. But did not worked. There is a windows boot icon automatically. I booted it. The same problem is there. 1. Laptop keyboard and touch pad are not working. 2. Can not see the sleep. Audio was not worked. I used my extrnal keyboard to type my password. And I followed your tuto… put the Misc/entries for windows and ubuntu. Named as them. Then reboot. They are showing as OTHER OS. Booted by them. But not working.
anto barreca Posted May 13, 2021 Posted May 13, 2021 (edited) 48 minutes ago, MsujE said: I tried. But did not worked. There is a windows boot icon automatically. I booted it. The same problem is there. 1. Laptop keyboard and touch pad are not working. 2. Can not see the sleep. Audio was not worked. I used my extrnal keyboard to type my password. And I followed your tuto… put the Misc/entries for windows and ubuntu. Named as them. Then reboot. They are showing as OTHER OS. Booted by them. But not working. And I followed your tuto… put the Misc/entries...this work with 3 separate drive it should work for you 1 drive with 3 os this https://www.youtube.com/watch?v=nMCyUxMoRMo for the audio which codec do you have realtek xxx? for the keyboard I don't know, Maldon is needed Edited May 13, 2021 by anto barreca
MsujE Posted May 13, 2021 Posted May 13, 2021 1 hour ago, anto barreca said: And I followed your tuto… put the Misc/entries...this work with 3 separate drive it should work for you 1 drive with 3 os this https://www.youtube.com/watch?v=nMCyUxMoRMo for the audio which codec do you have realtek xxx? for the keyboard I don't know, Maldon is needed I have to use bootkey for this. That is worked correctly for me. 1
Robson Eletrônicos Posted August 3, 2021 Posted August 3, 2021 ola gostaria de saber se o meu notebook é compatível com big sur? Notebook Dell inspiron i14-5458-B32P processador intel core i5 de 5° geração 12GB de Ram Eu coloco o pen drive dá boot normal começa a instalação mas não completa fica reiniciando... Alguém pode me ajudar?
Administrators MaLd0n Posted August 4, 2021 Author Administrators Posted August 4, 2021 11 hours ago, Robson Eletrônicos said: ola gostaria de saber se o meu notebook é compatível com big sur? sim https://www.olarila.com/topic/15040-opencore-vanilla-guide-2021-folder-for-chipsets-monterey-ready-desktop-and-notebook/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
mezzalira Posted August 11, 2021 Posted August 11, 2021 (edited) Fala @MaLd0n, tudo certo? Tenho a seguinte configuração na minha máquina: Asrock B450M Steel Legend Ryzen 5 2600 16GB de memória GTX 760 2GB SSD 120GB Meu Arquivo sendME https://drive.google.com/file/d/1-KsyRKeksRbzTsWjOANGxFvdBBR51VL3/view?usp=sharing Consegui rodar de boas ontem o Catalina, funcionando legal com duas telas. Porém, resolvi testar o Big Sur e não tem jeito de funcionar. To usando o boot EFI que você recomendou pro Ryzen e mais nada... Por gentileza, pode me ajudar nessa? Valeu! Edited August 11, 2021 by mezzalira
mezzalira Posted August 12, 2021 Posted August 12, 2021 MaLd0n, consegui resolver o problema mudando o modelo do Mac para iMac 14,2. Obrigado!
Administrators MaLd0n Posted August 14, 2021 Author Administrators Posted August 14, 2021 On 8/11/2021 at 10:14 PM, mezzalira said: MaLd0n, consegui resolver o problema mudando o modelo do Mac para iMac 14,2. Flw -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Posted by MaLd0n,
Chronology
Recommended by MaLd0n
1 reaction
Go to this post
