7 hours ago, Antiko said:
Trying to install Big Si's on the Asus x99 +e5-2640-3. I get this error. Is there any solution? Thank you for your help!
many x99 need a pci patch
1 hour ago, MaLd0n said:
многим х99 нужен патч pci
Thanks for the answer! What kind of patch? Catalina works perfectly. I will be very grateful for your help!
check ur catalina folder if have pci patch in kernel and kexts patches
I tried to run the installation and with the config from Catalina, but I got the error pci configuration begin. Could you give me a link to this patch?
https://www.insanelymac.com/forum/topic/335650-kernelandkextpatches-1013x1014x1015x-x99x299/
Thanks! Sorry for a rather stupid question - do these patches work in Openkore?
ye
On 8/2/2020 at 9:52 PM, MaLd0n said:
Guys. Big Sur is beta and problematic for now. The best solution in this case is via bootloader. Let's wait devs work.
does OC 0.6.0 unable to boot Big Sur 11.0 (Beta 3) on laptop??
It boots and everything but the only problem is that whatevergreen isn't loading and in OpenCore boot menu I can only boot via "Preboot" disk.
Edited by csv747
More info.
yes. beta 3
4 hours ago, xdevillived666 said:
my mic doesn't work
u try other layout?
https://www.olarila.com/topic/6074-guide-easy-audio-solution-with-applealc-clover-and-opencore/
8 hours ago, xdevillived666 said:
I tried generating hpet.aml, I have used ID 22 and 21 but both give same results. I'm sure I am missing something small just not sure what it is .
just try others layouts
7 hours ago, xdevillived666 said:
Hi guys, I am trying to update to beta 9 but get stuck here
kexts and bootloader is updated?
13 hours ago, xdevillived666 said:
Yeah. Sip enabled and securebootmodel disabled  too.
seems like a booter quirks problem
