5 hours ago, xdevillived666 said:
Thanks maldon. I'm a noob with opencore. Where can this be done on OC config.plist?
device properties tab
3 hours ago, xdevillived666 said:
my keyboard does not work
u update ps2 kext too?
I did. I'll have to do run me app again. Reverted to efi without aiportbrcmfixup and keyboard works. WiFi working was a false positive.
I have two drives
One with olarila restore big sur /Clover -everything works but cannot update it
Fresh install with OC on other ssdd with MacOS 12.0(beta 3) but cannot get WiFi to work
WiFi sometimes works if I reboot after logging into ssd with olarila , rebooting, cleaning nvram, and then going to beta 3 ssd . But wifi stops on reboot from.beta 3 ssd to beta 3 ssd
2 hours ago, xdevillived666 said:
I did.
extract one sendme
10 hours ago, MaLd0n said:
extract one sendme
Hi sir. Here is my sendme from my ssd where I installed big sur beta 3 with usb/OC. I cant upload directly because the zip is 6mb and it says I can only upload 2.93 mb??
https://drive.google.com/file/d/1iYHKcxrdPc4844MotV9xzynzEP7Z8dPj/view?usp=sharing
-update:
Formatted ssd and did a clean install. All is working for now. Must have been a mix up with nvram and the other ssd
Edited by xdevillived666
8 hours ago, MaLd0n said:
Hi sir. I am uploading a new run me via "we transfer" . My keyboard issue came back and it seems to only happen when airportbrcm is there. Ive tried everything to no success. I also think I uploaded the wrong file last time.
if this kext cause problem, report it in github for devs
Wasnt the kext. Was my stupidity. had to redo config.plist and make sure kexts loaded in proper order. Also had to disable voodooinput in voodoo12C
I need help!
On Beta 1 my OC is fine, but while I try update to beta 3, the verbose stuck on this line. Any idea what should I do?
Sometimes It got stuck on apfs_module_start:2411
I tried to put SSDT-EC-USBX and EC0 to EC but no differencies.
My Laptop is IP S340
i5-8265U
Intel UHD620
8GB 2400MHz
Thank you!
20200802_083922.zip
Guys. Big Sur is beta and problematic for now. The best solution in this case is via bootloader. Let's wait devs work.
