4 hours ago, MaLd0n said:
não subiu e nem parei pra olhar
Vinha tentando há 2 dias, até descobrir (agora há pouco) que o problema era com as kexts Voodoo que estavam causando Kernel Panic.
Desativei todas elas (VoodooI2C, VoodooI2CSynaptics, etc.) só no primeiro reboot e a instalação subiu normal. A partir do segundo reboot já pode ativar novamente.
Edited by Geoide
1 hour ago, Kyaalod said:
Yes sir. Im usong dell g7 laptop
remove battery plugin and test
how can I remove it? where? in kext? I'm using ACPIBatteryManager.kext btw
yes. remove it and try. battery cause this problem in many cases in new system
3 minutes ago, dudewith said:
Hey @MaLd0n  do we have a torrent link for this..? google drive is acting strange
hey. no. only drive
copy to ur drive and download
Hello Everyone,
I'm currently running Big Sur Beta 2 Clover on my HP Probook 430 G6 with @MaLd0n workaround. all function works like charm including my replaced wifi DW1820A. a while back ago I tried to upgraded to Big Sur Beta 3 with OpenCore, again from @MaLd0n workaround. what I did to upgraded is, I just copied mald0n EFI Premade for 1000, xxx to my EFi folder on Big Sure Beta 2 Installed on my laptop and upgrading directly from system update. as a result upgrade process running smoothly. But the issues is With OpenCore workaround I can't turn my wifi on, while in Clover its not problem.( with the same kexts) With Big Sur Beta 3 I cannot restore to Clover Anymore, cannot boot with it (while in Beta 1 & 2 Clover still works) that is the reason why I back to Beta 2.
I just confused OpenCore and Clover with the same kexts are works fine to my system with the same kexts form beta 1 to beta 3, but on OpenCore my Wifi issues still persist while on clover its not.
HP Probook 430 G6 | Core i5-8265u | Intel UHD 620
9 minutes ago, revans said:
wifi DW1820A
u used fakeid and "pci-aspm-default" properties?
compatible use pci14e4,43a0
On 7/24/2020 at 2:04 PM, neverday said:
Pode verificar? mesmo assim não sobe a segunda parte da instalação!
Não consegui visualizar sua config.plist (o ZIP que vc anexou aparece como "unavailable").
Se vc estiver usando kexts voodoo (ex.: VoodooI2C, VoodooI2CELAN, VoodooI2CSynaptics, VoodooPS2Controller, etc.), desative todas elas no seu config.plist (alterando o "Enable" de "Yes" para "No"). No meu caso funcionou, pois eram elas que estavam causando Kernel Panic na segunda parte da instalação. Depois que passar essa parte (na próxima reinicialização) vc já poderá ativá-las novamente.
Yes Sir I did it, even I tried all compatible id pci14e4,43a0, pci14e4,43ba, pci14e4,43b1, pci14e4,43b2 etc that show on IOreg brcm_Nic. the kext I noticed loaded on ioreg, but can't be able to turn wifi on. but its weird because when I look ioreg when I using clover, ID saw pci14e4,4353, I've tried to that ID on Opencore but no luck the result same, I cannot turn wifi on.
Sir @MaLd0n,
Hope you do research for issues Clover booting Big Sur Beta 3 purpose. So its can boot anymore like in Beta 1 & 2. ?
some new mistery in beta3?
1 hour ago, neverday said:
alguma dicas pra KP no beta 3 ?
são muitos. tem de aguardar uma solução real via bootloader
hey. no. only drive
should i use different battery kext??
first try with nothing about batt
5 hours ago, xdevillived666 said:
I have updated to beta 3 but now dw1560 isnt working. I have the correct kexts but when those brcm patchram 3, airportbrclfixup, etc are present, my laptop tops loading at apfs error
use fake dev id 43a0 and old brcmfix kext
