ur hardware dont have support in catalina
use a dosdude tool
thanks, I know but it's not working with the dosdude tool.
 macOS reboot infinitely after the half of the loading system.
I have update the firmware, but nothing change, it's for that I try with Olarila... have you a configuration for Clover?
High Sierra works and I have use Mojave but it's down after a apple update :(
macbookpro7,1 with 16Go RAM and 2 SSD
My problem with clover or directly with our version or installer dosdude tool patcher  : impossible to boot the installer key
Edited by greens
Hi man, i have the same MBP, with 8GB Ram, in this case you gonna try the Catalina's path to make a usb boot driver w/ this mod.
But on my case the battery worked less than 2 hours and system do not run faster like High Sierra and CPU Fan cooler running up 4000 rpm making a lot of noise.
Now i am using Linux Fedora 32 to work with MSCode to Python R. and C#
the Battery working a lil' bit good than on macOs Catalina and CPU fan  noise less
http://dosdude1.com/catalina/
