So I managed to get open core up and running on my surface pro 6
Currently using clover and it works but with the inevitable switch to open core and Big Sur i want to get ahead.
I followed the guide form dortania and it seems that everything is working minus a few things :
Cant get the UHD 620 to work only shows 19 mb
And battery indicator is not working at all.
I am linking to the EFi folder I have used if anyone can share some insights.
https://we.tl/t-BTYw1j4EaX
Thanks in advance
Shremi
the video patch is same for clover or opencore
So I followed a guide with clover and the steps are .
Boot until you get to the desktop with 0x12345678 .
Once you reach the desktop just rebuild cache and graphics should work. Natively.
Let me get home and I'll try without a graphics patch with opencore .
Here is the link to the EFI folder that works with graphics acceleration in clover @MaLd0n
https://drive.google.com/file/d/13hDB6ieXo8JJWbwfZl20DoV1hIb2EPUb/view
I am very new to opencore so can you just take a look and see what do I need to do .
I think this might be related to this:
Upgrading from 10.14.6 to 10.15.1, the DVMT MinStolenMemory Patch was changed as below, so I tried to change it in Kernel and Kext Patches page in Clover Configurator. (Also pay attention that the MatchOS should be 10.15.x)
macOS 10.15 (19A602) DVMT MinStolenMemory Patch by FireWolfKabyLake:Find: 0F82A703 0000Repl: EB04A703 0000
And in the 10.15.4 update, DVMT MinStolenMemory Patch is changed again:
Name: com.apple.driver.AppleIntelKBLGraphicsFramebufferFind: 0F828F03 0000Repl: EB048F03 0000Comment: Disable minStolenSize less or equal fStolenMemorySize assertion, 10.15 (based on Austere.J patch by PMheart)
the original one on 10.14.4 and 10.14.6 is:
Find: 764648FF 05
Repl: EB4648FF 05
this folder u just use inject intel
u can extract one ioreg with clover and check video properties
<00 00 16 59> and <16 59 00 00>
So I tried . 2 things
Uploaded images
The first one got to a black screen with backlight working.
The second one KP on com.apple.driver.AppleIntelKBLGraphicsFramebuffer
Can this be related to the patch I mentioned above ?
More info on the log of open core don't know if I'm doing this right:
00:000 00:000 OCC: No compatible mode for 1368x912@0 (max: 0) resolution
00:005 00:005 OC: Changed resolution to 1368x912@0 (max: 0) from 1368x912 - Not Found
02:858 02:853 AAPL: [EB|#LOG:INIT] 2020-07-22T03:28:13
02:862 00:004 AAPL: [EB|#VERSION] boot.efi 422.120.8~4 (Official), built 2020-04-25T13:40:44-0700
02:866 00:003 AAPL: [EB|#BUILD] BUILD-INFO[298]:{"DisplayName":"boot.efi","DisplayVersion":"422.120.8~4","RecordUuid":"B23C25AB-1BE0-4039-A2B9-F7CA74720D52","BuildTime":"2020-04-25T13:40:44-0700","ProjectName":"efiboot","ProductName":"boot.efi","SourceVersion":"422.120.8","BuildVersion":"4","BuildConfiguration":"Release","BuildType":"Official"}
02:869 00:003 AAPL: [EB|#H:IS] 0
02:873 00:003 AAPL: [EB|#WL:MODE] 0
02:876 00:003 AAPL: [EB|#CONFIG:SRC] <default>
02:880 00:003 AAPL: [EB|#CONFIG| 0] boot-save-log : 0x0000000000000002 (0x0000000000000002 < 0xFFFFFFFFFFFFFFFF) <default>
02:884 00:003 AAPL: [EB|#CONFIG| 1] wake-save-log : 0x0000000000000002 (0x0000000000000002 < 0x0000000000000002) <default>
02:888 00:003 AAPL: [EB|#CONFIG| 2] console       : 0x0000000000000001 (0x0000000000000001 < 0x0000000000000001) <default>
02:891 00:003 AAPL: [EB|#CONFIG| 3] serial        : 0x0000000000000000 (0x0000000000000000 < 0x0000000000000000) <default>
02:895 00:003 AAPL: [EB|#CONFIG| 4] embed-log-dt  : 0x0000000000000000 (0x0000000000000000 < 0x0000000000000000) <default>
02:899 00:003 AAPL: [EB|#CONFIG| 5] timestamps    : 0x0000000000000000 (0x0000000000000000 < 0xFFFFFFFFFFFFFFFF) <default>
02:902 00:003 AAPL: [EB|#CONFIG| 6] log-level     : 0x0000000000000001 (0x0000000000000001 & 0x0000000000000001) <default>
02:906 00:003 AAPL: [EB|#CONFIG| 7] breakpoint    : 0x0000000000000000 (0x0000000000000000 & 0x0000000000000000) <default>
02:910 00:003 AAPL: [EB|#CONFIG| 8] kc-read-size  : 0x0000000000100000 (0x0000000000100000 < 0xFFFFFFFFFFFFFFFF) <default>
02:913 00:003 AAPL: [EB|#H:IS] 0
02:917 00:003 AAPL: [EB|#WL|0] 0x01 0x01   0 0x00
02:921 00:003 AAPL: [EB|#BRD:NV] Mac-CAD6701F7CEA0921
02:925 00:003 AAPL: [EB|#WL|1] 0x01 0x01   2 0x00
02:928 00:003 AAPL: [EB|`BST:IDT] {
02:932 00:003 AAPL: [EB|`BST:IDT] }
02:936 00:003 AAPL: [EB|#WL|2] 0x01 0x01   3 0x00
02:940 00:003 AAPL: [EB|#WL|3] 0x01 0x01   4 0x00
02:943 00:003 AAPL: [EB|#BRD:NV] Mac-CAD6701F7CEA0921
02:947 00:003 AAPL: [EB|#WL|4] 0x01 0x01   5 0x00
02:951 00:003 AAPL: [EB|`H:CHK] BM: 0x0000000000000000
02:955 00:003 AAPL: [EB|`H:CHK] Err(0xE) @ GV boot-signature
02:958 00:003 AAPL: [EB|#WL|5] 0x01 0x01  23 0x0E
02:962 00:003 AAPL: [EB|`H:CPM] Err(0xE), (24, 24) @ GV Persistent-memory-note
02:966 00:004 AAPL: [EB|`SB:EN] Err(0xE) @ LocP 24B73556-2197-4702-82A8-3E1337DAFBF2
02:970 00:003 AAPL: [EB|#LIMG:DP] Acpi(PNP0A03,0)/Pci(1D|0)/Pci(0|0)/?[ 0x83 0x17 0x10 0x0 0x1 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 ]/HD(Part4,SigB28205E4-1594-4B21-8FB7-BF7C0D13ADA3)/VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842)
02:974 00:003 AAPL: [EB|#LIMG:FP] \A18E1E0F-8E34-4177-87F0-E667CB228D06\System\Library\CoreServices\boot.efi
02:978 00:003 AAPL: [EB|#LIMG:OPT] ()
02:983 00:005 AAPL: [EB|`OPT:LXF] 'LF (\\A18E1E0F-8E34-4177-87F0-E667CB228D06\\System\\Library\\CoreServices\\com.apple.Boot.plist)
02:987 00:003 AAPL: [EB|`LD:LF] FIO: 0, DIR: 1, P: \\A18E1E0F-8E34-4177-87F0-E667CB228D06\\System\\Library\\CoreServices\\com.apple.Boot.plist, DP: 0
02:991 00:003 AAPL: [EB|`LD:OFS] Err(0xE) @ OPEN (\\A18E1E0F-8E34-4177-87F0-E667CB228D06\\System\\Library\\CoreServices\\com.apple.Boot.plist)
02:994 00:003 AAPL: [EB|`OPT:LXF] Err(0xE) @ 'LF
02:998 00:003 AAPL: [EB|`OPT:LXF] 'LF (Library\\Preferences\\SystemConfiguration\\com.apple.Boot.plist)
03:002 00:003 AAPL: [EB|`LD:LF] FIO: 0, DIR: 1, P: Library\\Preferences\\SystemConfiguration\\com.apple.Boot.plist, DP: 0
03:006 00:004 AAPL: [EB:#KF] ()
03:009 00:003 AAPL: [EB|#MBA:CL] ()
03:013 00:003 AAPL: [EB|#MBA:NV] (-v debug=0x100 keepsyms=1 alcid=3 -cdfon)
03:017 00:003 AAPL: [EB|#MBA:KF] ()
03:021 00:003 AAPL: [EB|#MBA:OUT] (-v debug=0x100 keepsyms=1 alcid=3 -cdfon)
03:024 00:003 AAPL: [EB|#LOG:VERBOSE] 2020-07-22T03:28:14
03:028 00:003 AAPL: [EB|#OPT:BM] 0x84182
03:032 00:003 AAPL: [EB|`OPT:LXF] 'LF (\\A18E1E0F-8E34-4177-87F0-E667CB228D06\\System\\Library\\CoreServices\\PlatformSupport.plist)
03:036 00:003 AAPL: [EB|`LD:LF] FIO: 0, DIR: 1, P: \\A18E1E0F-8E34-4177-87F0-E667CB228D06\\System\\Library\\CoreServices\\PlatformSupport.plist, DP: 0
03:040 00:004 AAPL: [EB|#B:VAw]
03:043 00:003 AAPL: [EB|`P:DCCPR] Err(0xE) @ GV AAPL,CoProcessorReboot
03:047 00:003 AAPL: [EB|#P:MPI] N
03:051 00:003 AAPL: [EB|`CS:CSKSD] {
03:055 00:003 AAPL: [EB|`CS:CSKSD] Err(0xE) @ GV 8D63D4FE-BD3C-4AAD-881D-86FD974BC1DF:boot-info-payload
03:058 00:003 AAPL: [EB|#WL|6] 0x01 0x01   6 0x0E
03:062 00:003 AAPL: [EB|`CS:LFC] {
03:066 00:003 AAPL: [EB|`LD:LF] FIO: 0, DIR: 1, P: System\\Library\\Caches\\com.apple.corestorage\\EncryptedRoot.plist.wipekey, DP: 0
03:076 00:010 AAPL: [EB|`FS:AGSVH] Err(0xE) @ LocHB 59D76AE4-37E3-55A7-B460-EF13D46E6020
03:080 00:003 AAPL: [EB|`G:CS] } Ok(0)
03:086 00:005 AAPL: [EB|`LD:LF] FIO: 0, DIR: 1, P: <null string>, DP: 1
03:094 00:008 AAPL: [EB|`B:SBS] SZ: 617016
03:109 00:014 AAPL: [EB|#B:SHA] cd2d3bb2aa4ad73b0029d6e64346784012ab8492
03:116 00:007 AAPL: [EB|`WL:PWLFNV] Err(0xE) @ GV wake-failure
03:123 00:006 AAPL: [EB|`WL:DT] Err(0xE) @ WL:PWLFNV
03:129 00:006 AAPL: [EB|#WL:DT] 0xFF 0xFF 255 0xFF
03:135 00:006 AAPL: [EB|`FS:AGSVH] Err(0xE) @ 'AGU.0
03:141 00:006 AAPL: [EB|`FS:AGSVH] Err(0xE) @ 'AGU.1
03:149 00:007 AAPL: [EB|`LD:LKC] BPDK -> (System\Library\PrelinkedKernels\prelinkedkernel.development)
03:161 00:011 AAPL: [EB|`LD:OFS] Err(0xE) @ OPEN (System\\Library\\PrelinkedKernels\\prelinkedkernel.development)
03:170 00:009 AAPL: [EB|`LD:LKC] BPDK,!R -> (System\Library\PrelinkedKernels\prelinkedkernel)
06:862 03:691 AAPL: [EB|`LD:LKFS] } Ok(0)
06:869 00:007 AAPL: [EB|`LD:LKC] } Ok(0)
06:875 00:005 AAPL: [EB|#FWFM] 0xFF1FFF3F
06:881 00:005 AAPL: [EB|#FWFT] 0xFD0FF536
06:886 00:005 AAPL: [EB|#CSR:IN] 0x00000067
06:892 00:005 AAPL: [EB|#CSR:OUT] 0x00000067
06:898 00:005 AAPL: [EB|`BST:FBS] {
06:903 00:005 AAPL: [EB|`BST:FBS] BA.ADSZ: 0
06:909 00:005 AAPL: [EB|`BST:FBS] BA.KSDSZ: 0
06:917 00:007 AAPL: [EB|`B:WFDW] Err(0xE), 0 @ LocHB 71B4903C-14EC-42C4-BDC6-CE1449930E49
06:924 00:007 AAPL: [EB|#LOG:DT] 2020-07-22T03:28:17
06:931 00:006 AAPL: [EB|#LOG:EXITBS:START] 2020-07-22T03:28:17
Edited by shremi
Syntaxis
Tried both patches in that thread for uhd 620.
I was able to boot to a black screen with backlight sound works ok .
I just can't get video to work .
