On 11/25/2020 at 11:31 AM, MaLd0n said:
Hi, I looked at that website and I couldn't get it to work for Big Sur. I'm not using Clover at all, only OpenCore. What does it mean when it says "just inject via OpenCore"? And how is that different from in #3 where it says "here is the modification (no need injector)"?
One more thing is I noticed one of the two kexts that need to be injected (AirPortAtheros40.kext) has the same name as the one that doesn't need injection. I'm a little confused. I do have Big Sur up and running, but lack of Wi-Fi is a bummer.
On 11/25/2020 at 1:31 PM, MaLd0n said:
@MaLdOn, I made it all the way here, but is not working at all. It was working on Catalina last version but now with Big Sur 11.3 it shows me on Hackintool/PCIe my Qualcomm Atheros QCA9565/AR9565 but the system doesn't recognize it. I'm using a Dell Inspiron 15-3567, i3 6006U@2GHz, Intel HD520.
Versões de Software:
  CoreWLAN: 16.0 (1657)
  CoreWLANKit: 16.0 (1657)
  Extra do Menu: 17.0 (1728)
  Informações do Sistema: 15.0 (1502)
  Família IO80211: 12.0 (1200.12.2b1)
  Diagnóstico: 11.0 (1163)
  Utilitário AirPort: 6.3.9 (639.15)
Any ideas, pls?
Ola Maldonado.
Estou com um Dell vostro 3560 que tem ar9485 dw1703. Fiz o procedimento do FamilyModif porém a wifi fica mto lenta, nao chega a 1mb a velocidade e estou com bigsur instalado. Você sabe me dizer se realmente não tem como ter wifi total? Testei o procedimento do kextutility náo funcionou.
vc tem de trocar. use broadcom com suporte nativo
is AR9285 can work in Monterey? i can make it work only Big Sur or lower!
On 16/05/2021 at 00:11, Diego Mahilton said:
Ola Maldonado.
Estou com um Dell vostro 3560 que tem ar9485 dw1703. Fiz o procedimento do FamilyModif porém a wifi fica mto lenta, não chega a 1mb a velocidade e estou com bigsur instalado. Você sabe me dizer se realmente não tem como ter wifi total? Testei o procedimento do xtutility não funcionou.
Ola Maldonado.
vc tem de trocar esse wifi. é mt ruim
