Donation with Stripe https://tinyurl.com/2ssnydn6
Donation with BuyMeaCoffee https://tinyurl.com/bvsbpf6e
Donation with BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3
Donation with PicPay @danielnmaldonado
Donation with Mercado Livre https://tinyurl.com/y9evkj5u
1- Download KextUtility.
https://tinyurl.com/y256m57y
2- Download pack for your Wifi card.
*Lilu.kext is mandatory, if you don't have this kext, download and put in bootloader kexts folder*
-AR 9462
AR9462.zip
-AR9463
AR9463.zip
-AR9485
AR9485.zip
-AR9565
AR9565.zip
3- Drag ATH9KInjector.kext and IO80211Family_ATH.kext into KextUtility.app, put your Password and wait.
4- Reboot.
Atheros Bluetooth Kext
IOath3kfrmwr.kext.zip
Enjoy!
New way, check link bellow
https://tinyurl.com/yxgyatn9
Créditos: Apple, chunnann, Acidanthera Team, Pike R. Alpha, Bruno Souza
  • Thanks 2
2 hours ago, fortoszone said:
it works. but i got really slow even unusable connection
ofc
the best is change this card
Hi, anyone able to get bluetooth working with AR-9462 - 10.15.6?
EDIT: Nevermind :)
Edited by khevinpo
I was able to get my bluetooth working. Thanks.
I've found a solution from the guy that contributed to building the  Intel WiFi kext (zxystd). Here is the link to his blog for fixing AR9565 bluetooth: https://www.longzc.cn/index.php/archives/308 (it's in Chinese but google translate figures it out). You have to download the 2 kexts there and just put them in OC/kexts . It's a bit buggy but it works on cold boot. Here is the source code on GitHub: https://github.com/zxystd/AthBluetoothFirmware
you can write what you do to run bluetooth the way in this tutorial because not everyone translates this page.
@MaLd0n
Thanks very much for taking the time to do this! Doing it this way didn't work for me (on Mojave). BUT I was able to make it work by putting ATH9KInjector.kext, IO80211Family_ATH.kext, and AR9462 in /EFI/CLOVER/kexts/Other/ and rebooting.
Just thought I'd mention it in case others ran into a problem.
ThinkPad E531, L530, Inspiron 9400: Core 2 duo @2.16GHz , 4GB, G70 Geforce 7800 (10.7/Lion)
E531: i5-3230M, L530: i3-3110M, Optiplex 780: Core i5 @3.1GHz, 8GB, Geforce 8400 GS (10.9/Mavericks)
HD4000, A68HM-E33 V2 (MS-7721): Athlon X4 860K, 8GB, GeForce GT 730 (10.9/Mavericks)
Enjoy!
Can you send me the files?
Bluetooth kext
this link is not working
13 hours ago, abookhaled2000 said:
DW1510
is a broadcom card no?
4 hours ago, abookhaled2000 said:
BCM4322 802.11a/b/g/n Wireless LAN Controller
i think loose support
check here https://github.com/acidanthera/AirportBrcmFixup
