xKaoSx Posted July 19, 2020 Posted July 19, 2020 Hi everyone, I am English very bad I am so sorry. I have a Clover and DSDT Battery working but change my bootloader on OpenCore. OpenCore Bootloader say to not run DSDT only SSDT Hotpatch. I try to SSDT-BAT.aml but not working. I am don't know ACPI language. Please help me. My original DSDT-SSDT dump is attachment. Original.zip
Administrators MaLd0n Posted July 19, 2020 Administrators Posted July 19, 2020 post one full dump https://www.olarila.com/files/Utils/RunMe.app.ziphttps://www.youtube.com/watch?v=k9wmIfGLe3A 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
xKaoSx Posted July 19, 2020 Author Posted July 19, 2020 File is attachment. Thank you so much. https://yadi.sk/d/X0hLKWVH-i7N-Q
Administrators MaLd0n Posted July 20, 2020 Administrators Posted July 20, 2020 DSDT.aml.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
xKaoSx Posted July 20, 2020 Author Posted July 20, 2020 (edited) Thank you @MaLd0n so much. But you wrong understand me maybe my English very bad. I have same DSDT.aml with battery patch and running Clover bootloader not problem. I am change bootloader to OpenCore and problem starting is this point. OC guide is write "Note that you should not add your generated DSDT.aml here, it is already in your firmware. So if present, remove the entry for it in your config.plist and under EFI/OC/ACPI." If you create to Battery Hotpach SSDT ? Edited July 20, 2020 by xKaoSx
Administrators MaLd0n Posted July 20, 2020 Administrators Posted July 20, 2020 42 minutes ago, xKaoSx said: "Note that you should not add your generated DSDT.aml here, it is already in your firmware. So if present, remove the entry for it in your config.plist and under EFI/OC/ACPI." is wrong add ur dsdt there and delete a bunch of non-sense ssdt here is full vanilla, not pseudo vanilla 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
